Old 21-07-2009, 11:09 PM   #1 (permalink)
mortal kombat
quan chi's Avatar
Default urgent help required.
guys i please beg you to go to this post before continuing here.
http://www.chip.in/forums/viewtopic....441550#p441550
http://www.chip.in/forums/viewtopic....441976#p441976
plese tell me a cheap mobo which should support.
1.pentium 4 ht 3.0ghz(i mean my old processor)
(even if it supports core2 duo and also a p4 ht it will do)
2.ddr rams.(it is must)
3.should have a pciex16 slot.
in short it should be equivalent to asus p5gl-mx(my current mobo)
quan chi is offline
Old 21-07-2009, 11:16 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: urgent help required.
D945
D946
D33U
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline
Old 21-07-2009, 11:56 PM   #3 (permalink)
mortal kombat
quan chi's Avatar
thanks for the reply but please mention the brand and price.
quan chi is offline
Old 22-07-2009, 12:56 AM   #4 (permalink)
Point Blanc
get boards from MSI/Asus, will do you good, support DDR2 RAM upto 4GB
how old is your proccy,
you actually need to first identify whether it is 478 pin or LGA775 pin proccy, on the basis of that only u can buy a new mobo.
acewin is offline
Old 22-07-2009, 07:35 AM   #5 (permalink)
Yes, be sure of that otherwise you will be wasting your time. I also had to change my motherboard once while retaining my P4, and I went for 945G (in 2007).
bippukt is offline
Old 22-07-2009, 09:45 AM   #6 (permalink)
mortal kombat
quan chi's Avatar
LGA775 its about 3 and a half years old.
quan chi is offline
Old 22-07-2009, 10:01 AM   #7 (permalink)
mortal kombat
quan chi's Avatar
DOES THIS MOBO SUPPORTS INTEL PENTIUM 4 3.0GHZ HT PROCESSORS Asus P5N MX http://www.dealtime.com/xPF-ASUS-Mot...-Vid-Aud-SATA3
I NEED A MOBO WHICH SHOULD SUPPORT HT ALSO.
and should have REALTEK 10/100 LAN CONTROLLER
quan chi is offline
Old 22-07-2009, 11:43 AM   #8 (permalink)
Excessive happiness
furious_gamer's Avatar
@quan chi
I am exactly having the same mobo, ASUS P5N-MX and i previously used it with my P4 HT 3.06GHz proccy and OCed it to 3.72GHz.Now i ran E6600 in this board and OCed that to 3.2GHz from 2.4GHz. Stable board.
It do supports HT. And the same LAN Controller as you mentioned. No problem. Good board.
Whether you buy it as new or used one. If used one, then go for it. Or else get
P5K PL-CM as they both available at same price.
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is online now
- by kool
- by ax3
