Old 17-07-2009, 05:43 PM   #1 (permalink)
ay_aceoo7's Avatar
Default help plz....
administrator has prohibited access to cd/dvd rom drives......and my pc wont read any cd or dvd's .....wat's the problem?....if anyone know plz help....
ay_aceoo7 is offline
Old 17-07-2009, 06:31 PM   #2 (permalink)
Default Re: help plz....
When you ask a question like this,
1. Give some indication of the problem in the subject line. Otherwise, many readers will not bother opening the thread. Something like "Access to CD/DVD drive denied".
2. State your OS. Very important for this type of question.
3. Use normal fonts except for certain words you want to highlight.
3. Say how and when the problem started, and give as many details as you can. E.g., does the drive show up where it's supposed to be or is it invisible?
pimpom is offline
Old 17-07-2009, 06:35 PM   #3 (permalink)
Shouldn't this be in the software troubleshooting section?
Intel D930&945GNTL| 2x1GB 667 Mhz(Transcend+Kingston)| 500GBSeagate+200 GB WD|Zotac 9600GT Amp!| Zebronics Platinum 400W|Dell SP2208WFP|Logitech z5500| Lite-onDVD-RW+LGDVD-R
emmarbee is offline
Old 17-07-2009, 06:38 PM   #4 (permalink)
Democracy is a myth
rhitwick's Avatar
Question Re: help plz....
4. Say how and when the problem started, and give as many details as you can. E.g., does the drive show up where it's supposed to be or is it invisible?
+4
And more important, does that PC belongs to u or its in a restricted domain where u get to use it.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 17-07-2009, 07:24 PM   #5 (permalink)
<Sparkling Pwnies>
Anorion's Avatar
^ yeah, listen to PimPom, and give details...
check the connections
IDDQD IDKFA
Anorion is offline
Old 17-07-2009, 07:47 PM   #6 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
BTW, in an environment where everything is soft-blocked (i.e, using software in windows) consider using a bootable moblin pendrive. I could just insert it into the usb port and boot it in 10 seconds to a custom instant-on desktop to browse the internet, view files, etc.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 17-07-2009, 09:05 PM   #7 (permalink)
jatt's Avatar
first put your problem in details,then you can get reply according to that.thanks
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
jatt is offline
- by ax3
