Old 16-07-2009, 12:41 PM   #1 (permalink)
Default 22" inch monitor query .
will a 22"inch lcd monitor work on a system with nvidia 6100 based motherboard ? i mean will i be able to play games like nfs most wanted and watch movies in it . i am not looking in to high performance games .
Dont die of ignorance .
digitizen is offline
Old 16-07-2009, 12:51 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: 22" inch monitor query .
most of the current 22" monitors come with FullHD and I don't think you can game on it using 6100 chipset.
your best bet would be 19" or less. or get a Graphics card
desiibond is offline
Old 16-07-2009, 12:54 PM   #3 (permalink)
will there be any problems with video playback aswell ?
Old 16-07-2009, 01:11 PM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
^^ that depends, if u r talking abt HD, then I don't think u'll be able to play HD videos. Its better if u buy a graphics card first.
Blogging at:
Technostarry
saqib_khan is offline
Old 16-07-2009, 01:34 PM   #5 (permalink)
ah ok . i am on a low budget . i thought ill buy the monitor and go for the graphics card a litle later .
Old 16-07-2009, 01:44 PM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
a 20" 2033SW for 7k and a HD4670/9600GT for 4.5k should be a good deal.
Old 16-07-2009, 01:49 PM   #7 (permalink)
can you give me an idea about the size difference ? i mean is that a huge difference because i am buying it for my bedroom and i also intend to watch tv on it with a tuner .
Old 16-07-2009, 02:13 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
hmm. 22" is too much if you are going to watch TV using a tuner unless your tuner support FullHD resolution. There will be lot of pixelation. Also, check LG's new 22" TV+monitor lcds. They come with inbuild tv tuner and you won't need to connect any external tuner. Price should be around 14k I think.
Old 16-07-2009, 02:44 PM   #9 (permalink)
so normal lcd tv tuners that come for 1500 wont support 22" lcd monitors ?
Old 16-07-2009, 03:53 PM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
they do support but the image will be stretched.
Old 16-07-2009, 04:20 PM   #11 (permalink)
You should not buy 22",since you require new TV tuner + graphic card for the same.
If you are low on budget then go for "19" or 20" WIDE SCREEN" monitors with HD support, so that in future you can add graphic card as well.
Mr.Digital is offline
Old 16-07-2009, 06:57 PM   #12 (permalink)
Buy a 22" FULLHD resolution Monitor and wait patiently until u gather funds for video card. With 6100 u can't play most of the games - even in 19" (1440x900)
22" and 24" FULLHD Recommendations
BENQ E2200HD - <10K
SAMSUNG 2233SW - 10K
BENQ G2412HD - <13K
DELL S2409W - 15K (not sure)
The reason for mentioning about the 24" is that they aren't too costly and if you intend to watch movies from some distance in your bedroom - a BIG screen will be sweet than buying a smaller screen and getting itchy about that 2" INCH LESSer (which I feel now)
What's your CPU? - It is the main requirement for you to play HD movies. Of course, now NVIDIA has enabled CUDA acceleration and you can play HD movies with your video card - but I 'm not sure whether it supports older cards too!
I've got a D930 processor and it easily plays 720p movies but 1080p with some hiccups. So now I use NVIDIA CUDA on my 9600GT card to play lovely HD clips on my 22" monitor.
Recommendation:
Buy a 22"/24" FullHD monitor - Working with a large widescreen monitor is a treat. YOU got ample space. For the time being, play the games with less resolution (OR play in window mode with black background). After you get some funds you can buy the video card and be pleased with quality FULLHD games. Happies Endings
BUT if you buy a NON fullHD monitor now, for say around 7-9K, later you'll feel for not being able to see quality 1080p clips until you ditch this monitor.
Intel D930&945GNTL| 2x1GB 667 Mhz(Transcend+Kingston)| 500GBSeagate+200 GB WD|Zotac 9600GT Amp!| Zebronics Platinum 400W|Dell SP2208WFP|Logitech z5500| Lite-onDVD-RW+LGDVD-R
emmarbee is offline
Old 16-07-2009, 07:57 PM   #13 (permalink)
BENQ E2200HD - <10K
BENQ G2412HD - <13K
Recommendation:
thanks for the awesome reply . and i would be able to watch tv with a tuner card.
Old 16-07-2009, 10:18 PM   #14 (permalink)
TechTin.com
ravi_9793's Avatar
Dell S2409W Full HD Monitor ->>PRICE : Rs 12750/- (3 Years Warranty)
ravi_9793 is offline
Old 17-07-2009, 11:55 AM   #15 (permalink)
I M A *STAR*
saqib_khan's Avatar
emmarbee is correct, monitor is something that we don't buy every now and then. So, for now buy a 22" LCD and later insert a graphics card.
Blogging at:
Technostarry
Old 17-07-2009, 12:30 PM   #16 (permalink)
Bond, Desi Bond!
desiibond's Avatar
also, as per nVidia
300 MHz RAMDAC
Blazing-fast RAMDAC supports display with high, ergonomic refresh rates up to and including 1920x1440@75Hz.
Single-Link DVI Support
Able to drive flat-panel displays up to and including 1600x1200.
Feature only available for GeForce 6150/nForce 430.
you need to be sure if this 6100 can drive a FullHD display. what is the use if it eats up lot of CPU cycles?
Old 17-07-2009, 12:44 PM   #17 (permalink)
The Master Chief
Ronnie11's Avatar
erm...pls don't mind me posting here but i kind of had the same question & thought it would be better to put it here...So if i plan to buy a 22/24" & enjoy full hd...so i have to buy a graphics card..so which cards would support full hd??are the hd cards very expensive??Could u guys pls suggest some cards to go with the 22/24 screens...
Ronnie11 is offline
Old 17-07-2009, 12:49 PM   #18 (permalink)
Bond, Desi Bond!
desiibond's Avatar
even a 1.5k 8400GS/GT will support FullHD. but make sure your mobo supports PCI-E
Old 17-07-2009, 01:07 PM   #19 (permalink)
The Master Chief
Ronnie11's Avatar
LOL...WHAAAAT???I thought u have to spend like 10k+ for an hd card...lol...but will these cards also be good to play games in full hd???Any good cards u would recommend for about 6k which supports full hd & gaming...nvidia or ati sapphire..whichever...
Ronnie11 is offline
Old 17-07-2009, 03:04 PM   #20 (permalink)
@digitizen - You still haven't given me your CPU model number?
@Ronnie11 - Palit GF GTS250 512MB DDR-III [HDMI] - 7250/-
Palit HD4670 Super 512MB DDR-III [HDMI] - 4725
Palit GF 9600GT 512MB DDR-III [HDMI] - 5000
Palit GF 9800GT 512MB DDR-III [HDMI] - 6200
And what about your screen - did u decide which one?
@ravi_9793 - Where did u get that price? If others new - please let me know.
And samsung 2233sw has come down to Rs. 9800 at deltapage and 10,250 at Lynx.
emmarbee is offline
Old 17-07-2009, 03:22 PM   #21 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@Ronnie11, my pick would be Palit GTS250 for 7k-7.5k if you want FullHD gaming + playback.
8400GS is card for hometheatre setup where it can easily drive a fullHD movie but not gaming at FullHD.
Old 20-07-2009, 12:58 PM   #22 (permalink)
Sorry for posting my query here as i cant create threads.
My CRT just got screwed and i need an LCD soon. This will be used with my old comp till I can get a new comp (waiting for ATI 785 boards). Now my current comp is an INTEL 845 board with onboard graphics and the new LCD should work with it for the next 3 weeks or so. Budget is about 7.5k (max stretchable to 8k) and I think 19 and 20 inch LCDs fall under this budget. Also note that I am planning to put atleast a 4850 card in my new comp.
So basically suggest an LCD priced <8000 which would work with my current system (845 based onboard card) and also a new system ( HD4850 , phenom 550, ddr3) . Please include the approx price at SP road bangalore. Thanks
shoaib89 is offline
Old 20-07-2009, 01:07 PM   #23 (permalink)
Bond, Desi Bond!
desiibond's Avatar
samsung 2033SW 20" LCD for 7.2k
Old 20-07-2009, 05:30 PM   #24 (permalink)
The Master Chief
Ronnie11's Avatar
Thanks but its a DDRIII card isn't it??so my computer won't support it then...
Intel Core I5 2500K,Gigabyte GA P67A UD3 B3,Corsair Vengeance 4gb DDR3,CM430 Cabinet,Corsair VX550W,Razer Cyclosa Bundle,Seagate 250GB,500GB,1TB,MSI 5770 hawk
Ronnie11 is offline
Old 20-07-2009, 05:41 PM   #25 (permalink)
Bond, Desi Bond!
desiibond's Avatar
This post seriously needs to be mentioned in "dumbest things thread"!!!
Ronnie, DDR3 card means that the RAM that is on the card is GDDR3 and doesn't fcuking care about what kind of RAM your PC has. Understand?????
Old 20-07-2009, 11:44 PM   #26 (permalink)
The Master Chief
Ronnie11's Avatar
Lol..dude i meant GDDR3..am sry about it...i wasn't talking about the ram..mine is 2gbddr2 ram...the quesry i had was what is with the DDR3 written...wasn't familiar with DDR3 stuff on graphics card..am familiar with RAMS man...Sry again...
PalitGTS 250512 MB DDR37375
Ronnie11 is offline
Old 21-07-2009, 12:19 AM   #27 (permalink)
Point Blanc
, thats scary desiboy getting angry, seems why the songs were written like of in Don, sure there will be like those in Bangalore too geeZ.
@shoaib, too bad your display got kaput, buying samsung 2033SW is very good option very good budget monitor, 845 chipset will do good, but playing movies with high res will be trouble, normal DVDrips will be ok, will take CPU load but then wont suggest to buy a bad low end GPU when u are already planning for big thing..
anyhow once you have bought you can tell us what was the experience,
@ronnie, the suggestions for such upgrades is based on the current config, and you never told what you have got currently. for systems like P4 and even pentium D, max upgrade suggestion will be HD4670. for dual cores likes of 2xxx max to 9600GT, and from E5200, more better gfx card.
remember if gfx card is high end and proccy sucks it wont be able to handle your gpu cycles.
acewin is offline
Old 21-07-2009, 09:25 AM   #28 (permalink)
Sure. Thanks for the suggestions. Will be buying it today or tomorrow and i will let you know how it goes. Its only a short term thing for my current comp so lets see.
shoaib89 is offline
Old 22-07-2009, 12:07 AM   #29 (permalink)
This is the first time I've seen desiji talking like this. What happened bhai?
And acewin, can my D930 processor handle the CPU cycles of 9600GT? if I upgrade my proc. can I see few more performance increase from my GPU?
emmarbee is offline
Old 22-07-2009, 01:09 AM   #30 (permalink)
Rubik's Uncle!!
Charan's Avatar
whats the current price of Dell E228WFP and E2208WFP? are these the best 22" monitors available? Main purpose - HD content.
Charan is offline
- by ax3
