I have finally selected the processor that is amd x2 7750BE....3.5k
i have finally list down some motherboards...
Biostar TA780G M2+ which is around 3.5k
is it a good choice because i am very tight on my budget.....my budget for mobo+procc. is strictly 7k.
please suggest me appropriate....
also i took into consideration asus,gigabyta780g mobos, and biostar ta790gxb mobo, but all of these are for price around 4.5k....
i also considered intel config....
or can i go with
intel e5200 + gigabyte g31 mobo in 6k...
but how good is the performance of this g31 graphic card???
i am gonna use it for multimedia and casual gaming(fifa).....
plzz give me ur suggestions as soon as possible as i am going to buy my pc tommo.
thank you!!!!!!!!!
also i want to know that what is diff between biostar a780g and ta790g
