So a neightbour has a problem, his PC starts then stops after a couple of seconds .
I opened his case , just looked around couldn't figure out anything.
SO the next day he got an engineer to look into it.
Now the engineer has identified the problem, but its something I have never heard of, he is saying there is some problem with the power button/wire connecting the power button. and will have to get the cabinet replaced.
Does this make any sense ??
he is getting his PC upgraded by the same engineer.
Edit: his pc is set to start when AC power is switched on . i.e when you switch on the main power the PC automatically starts. Now ofcourse its starts and then stops. What I don't understand is how can the power button be the problem in this case ( since the PC starts automatically)
