Old 13-07-2009, 10:22 PM   #1 (permalink)
speedyguy's Avatar
Default Xbox 360 hangs
A few times there was a red light glowing at startup bt now it hangs or freezes aftr running abt a few minutes. I suspect thr s a heating issue. But wat shud i do abt it? Itsa 2006 model so out of warranty.
Waiting fr ur reply. Thanx in advance.
Enjoy~!
No Pain...No Gain
speedyguy is offline
Old 14-07-2009, 04:19 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Xbox 360 hangs
see if you can add additional fans to your xbox 360.
desiibond is offline
Old 14-07-2009, 07:12 AM   #3 (permalink)
15.0 GHz
VarDOS's Avatar
keep u r XBOX Vertical if its horizontal, and keep it where it can get enough air, If not worked still update the firmware.
VarDOS is offline
Old 15-07-2009, 04:30 PM   #4 (permalink)
speedyguy's Avatar
hi thanx fr ur reps....i have ordered a console replacement from microsoft...they will b shipping it in 3 days... it was placed in vertically.... but i think ventilation wasnt very good as it was kept in the shelf on a tv stand...its open from front only n closed from other 3 sides.... wat kind of env shud i keep it in... will ensure next time 2 avoid this...giv examples...
Enjoy~!
No Pain...No Gain
Old 15-07-2009, 04:33 PM   #5 (permalink)
Ethan_Hunt's Avatar
Just pray you get one of the Falcon models as a replacement. It should possibly reduce the chances of an RRoD compared to their old 2006 batch.
V for Vendetta
Ethan_Hunt is offline
Old 15-07-2009, 05:45 PM   #6 (permalink)
The newest model is Jasper, Falcon is old.
letmein is offline
Old 15-07-2009, 09:20 PM   #7 (permalink)
speedyguy's Avatar
arre chill guys... m sure they wont give me any modified model...they wud provide me wit d same i had...mine was bought in 2007
Enjoy~!
No Pain...No Gain
Old 15-07-2009, 09:50 PM   #8 (permalink)
damnbadman666
damngoodman999's Avatar
RROD is less in jasper model but not completely over , unless u make some cooling needs - get 4 120m cooler master fans modd ur Xbox side panel connect it with simple SMPS for 300/- this is blow maximum AIR - so more cool - we did it for our friend , he plays 20 hrs per day since working perfectly
damngoodman999 is offline
Old 15-07-2009, 09:54 PM   #9 (permalink)
damnbadman666
Some Tips for Xbox360
Enjoy!!!
Old 16-07-2009, 07:32 PM   #10 (permalink)
speedyguy's Avatar
Enjoy!!!
"damn good man "
Enjoy~!
No Pain...No Gain
Old 17-07-2009, 05:15 AM   #11 (permalink)
Ethan_Hunt's Avatar
Dude I'm not a newbie here. A Jasper won't be provided as a replacement for his old core console. It would either be a old stock that they would replace it with or a fairly upgraded one, which would be Falcon. Plus we don't even have any sign of Jasper based boards out here in India. Most of the recent Arcade models have a manufacturing date of Dec 2008. So they could either be Jasper or Falcon models.
V for Vendetta
Old 17-07-2009, 09:51 AM   #12 (permalink)
speedyguy's Avatar
hey i wud b recieving the shipping soon.... so can u tell me how to figure out which model m getting... sry no idea abt falcon n jasper models
and also.. how can i check for its well being within a matter of minutes!!!
Enjoy~!
No Pain...No Gain
- by ax3
