Old 08-07-2009, 01:37 PM   #1 (permalink)
static_x's Avatar
Default Phenom II X4 940 3.0GHz
I've recently installed this processor to my system with Gigabyte 790GP-UD4H mobo. When i see the system properties it shows:
AMD Phenom II X4 940 Processor 743 Mhz
2.75 gb RAM.
I just wanted to know why it is showing it as 743 MHz when the processor speed is 3.0 GHz?? what could be the reason and how to fix that?
Phenom II X4 940, Gigabyte MA790GP-UD4H, Corsair 6GB DDRII, AOC Fovi F22, Creative Gigaworks T3 Speakers, NZXT Phantom, Corsair GS600, 15 TB HDDs, Shure SRH440, Klipsch S4i, Ipod Touch 64gb
static_x is offline
Old 09-07-2009, 12:53 PM   #2 (permalink)
Default Re: Phenom II X4 940 3.0GHz
System properties shows the current CPU frequency. If AMD Cool n’ quiet is enabled, it throttles the CPU. So, according to your usage, the frequency is reduced at low load. If you want to see the full 3GHz in the system properties, go into the BIOS and disable Cool n’ quiet. If it doesn't work, try upgrading (flashing) your BIOS to the latest version. Hope that helps.
otpsurvive is offline
Old 09-07-2009, 01:32 PM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@static_x, what otpsurvice said is bang on point. Just disable Cool'n'quiet if you want to have it running at max speed all the time. But you can ignore it if you want to have energy-efficient setup.
Though it shows low speed, when you do cpu intensive task, it will go up. Try to encode a video or cpu intensive task and while the task is running, check cpu speed.
desiibond is offline
Old 13-07-2009, 03:25 PM   #4 (permalink)
static_x's Avatar
thanks a lot to both of you...i got the point even before reading this...thanks anyways..
static_x is offline
- by ax3
