Re: USB port not working!!!!!
There maybe some USB device connected to your computer which is showing this error. If you haven't installed it's drivers then it will show like that. If you have got the drivers then install them.
And if it is coming on it's own(without any new hardware connected) try uninstalling the device? Rightclick the device, select properties and in the Driver tab, select Uninstall.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
