Old 08-07-2009, 07:00 AM   #1 (permalink)
Debian Gnu/Linux User
Sathish's Avatar
Default Help me.. 8GB Kingston DataTraveller Pen drive..dead slow
recenty i have bought Kingston 8GB USB Flash drive..
while i copy 2GB of files (Winpen pack), it take 50 to 55 minutes..
transfer speed is
500+kbps after formatting FAT32 and
900 kbps to 1.10 mbps after formatting NTFS
i have shocked about its performance..
i have checked the pen drive and my system for malwares and its clean.
pl help me to find out the reason..
Living for Learning & Learning for Living
Sathish is offline
Old 08-07-2009, 07:08 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Help me.. 8GB Kingston DataTraveller Pen drive..dead slow
are you sure that it is original? you shouldn't be getting that low transfer speeds.
desiibond is offline
Old 08-07-2009, 07:27 AM   #3 (permalink)
Sathish's Avatar
yes i have the original one with bill..
and it has 5 year warranty ..
Sathish is offline
Old 08-07-2009, 07:33 AM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
hmm. did you check in any other machine. Also, try reinstalling USB drivers. Looks like the usb stick is recognized as USB 1.1 stick and hence the reason for low speeds.
Old 08-07-2009, 07:42 AM   #5 (permalink)
Sathish's Avatar
no low speed warning for usb.1.1.. it takes recong as usb.2..
my 2GB transcend works perfectly..
can i replace with new one.. (bought on 2nd of July 09)
Sathish is offline
Old 08-07-2009, 09:19 AM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
take it the dealer and let him try the same from his PC. If it is the same there, ask for a new one.
- by ax3
