| Forum |
#1 (permalink) |
1)I switch on the main power 2)I switch on my UPS 3)I switch on my Power Button 4)Power LED(Blue) turns on. 5)HDD LED turns on for .3 secs and then goes off 6)Monitor turns from Active Power Mode to Standby Mode. 7)All the Cabinet fans and SMPS,CPU and GPU fans are running fine. 8)I press the power button for 3 seconds. 9)Voila!Machine reboots fine. Last week only I had the same problem,when I was suggested to flash my BIOS with the latest update.I did and since then,till today,system was running fine. I also would like to give the following info: 1.My BIOS does NOT go to the POST state. 2The monitor gets active signal just for a second and then it goes to Standby Mode. 3.Since the last time I flashed my BIOS(I flashed it on June 26th),I hear no beep sounds even when the machine boots normally.Not a single beep sound. 4.I believe my system has quite adequate ventilation.I checked from time to time earlier using Speedfan.Neither the HDD nor the CPU cores ever crossed 60 degrees Centi even after intense gaming.There are five 120mm Cabinet fans(two I bought separately) 5.My HDD was checked with Seagte Seatools and worked fine. What is the root cause?What do i have to do to rectify it once and for all??Even If I format there is no guarantee that this problem wont occur again. Regards AD
Amitava@ C2D 2.66GHz,ASUS P5QE,Palit Radeon HD 4870 Sonic 1 GB Dual Edition,Corsair 2X2 GB 800MHz,Seagate 500 GB at 7200.11 with 32MB cache,Corsait TX 650 W,Dell E1909 W 19",Cooler Master CM 690 |
#3 (permalink) |
666
reset your bios by setting the jumpers.. (refer mobo guide for jumper location)
MSI-P35-NEO| C2D-E7300 | XV-9600GT | WD-640 | LEADTEK-DTV-1800H | CORSAIR-TWIN2X2048-6400C4DHX | ZEBRONICS-PRO M500W | SONY-DRU-V200S | LOGITECH-X90 CORDLESS |
#4 (permalink) |
I haven't done this before.Could you please tell me how to go about it?A step by step guide...
#6 (permalink) | |
Super Moderator
1. Power down the system 2. Remove all power connection --> Physically disconnect the TX650 connector the the PSU. 3. Carefully (preferably with a thin screw driver or safety pic), remove the CMOS button cell. 4. Read the newspaper 5. Put the battery back in. 6. Power up. This will reset the system. Try this and let us know..!
MSI P45 Platinum(BIOS v1.7B)|Q9550[E0]@3.85Ghz@1.320V[453x8.5]MCH@1.184V|ICH@1.55V|DDR_V_Ref_A_B@1.05V|NH-D14|Corsair TWIN2X4096-8500C5(5-5-5-15)@1089Mhz@2.14V 2xHD4890[Xfire]@1000/900[MEM/GPU]|Corsair 650TX|Seagate180GB+80GB+WD1TB|SONY-DVD-R|CM690|2x120mm Scythe Ultra Kaze|DELL S2409W|APC 1100VA|Scythe Kaze Server Windows 7 Ultimate RTM - 64BIT|Catalyst 10.5 (8.14.10.0753) forced with RadeonPRO|PS3 160GB|Sony 40EX520|AC Ryan POHD Mini|APC 800VA|APC 800VA|D425KT|CM100 Elite|2TB WD|Acer D255 Test your spoiler tags before submitting |
#7 (permalink) | |
BIOS Details: Model 5Q-EVersion:2101 Chipset:Eaglelake BIOS type:AMI BIOS Size:2048K
#8 (permalink) |
Super Moderator
Hi..
It seems you have a short or leak in your system some where. It is causing the CMOS battery to drain out fast. STOP flashing your BIOS over and over again. Just put it back to the latest version. 'Bread box' your system and try to run it..with a new CMOS battery. Bread Box = remove the mother board, and place it on the table. Keep some non conductive material below it. Like thermocoal sheet, or a foam pad, or 2-3 mouse pads. Hook up the processor, heatsink, ram (one stick only), GPU, HDD (only the one with the OS), monitor, keyboard and mouse. Now try to run it...?? Make sure all system settings are stock. RUN IT..STRESS IT..Report back..
#9 (permalink) |
Guys the problem,I think ,has been solved!For the past few days,it seems that one corner of my Mobo had been grounded to the metal chassis,due to the nut coming loose..This led to voltage fluctuations and subsequent booting problems.Now the machine boots fine with a single beep everytime.
My question is:Is there a possibility that my Mobo,specially the condensers & capacitors situated near the grounded portion,has already been damaged to some extent?Is there any way to know if my severely tortured Mobo is perfectly all right?
Amitava@ C2D 2.66GHz,ASUS P5QE,Palit Radeon HD 4870 Sonic 1 GB Dual Edition,Corsair 2X2 GB 800MHz,Seagate 500 GB at 7200.11 with 32MB cache,Corsait TX 650 W,Dell E1909 W 19",Cooler Master CM 690 Last edited by Amitava83; 09-07-2009 at 03:14 PM. |
#10 (permalink) | |
Super Moderator
Just to confirm that there are no more leaks, check your cabinet metal with a line tester. It should not glow even dimly. Even if you have a dim/faint glow, current is leaking in somewhere. I had the same issue, three days ago. Specially called the electrician to get my home earthing rectified..!
#11 (permalink) |
Guys,problem still not solved.Even after all this,I again get the same problem:viz BIOS freezes befpre even going to POST...and MOST IMPORTANTLY ,there is NO BEEP when it occurs.After I press the Power Button for some seconds,BIOS boots up normally with single beep.
I'm having nightmares.Please help!
#12 (permalink) |
#13 (permalink) |
Super Moderator
Try what I suggested..BREAD BOX it..
| Bookmarks |
| Thread Tools | |
| Display Modes | |
