Old 04-07-2009, 11:13 PM   #1 (permalink)
harishgayatri's Avatar
Question Need to buy PCI Sound Card Budget based
Hi,
I would like to buy a Sound Card with Optical or Digital Out options.
It is supposed to be PCI based not PCIe and also good value for money.
I would be connecting it to my Home theater System for watching HD movies with mostly DTS audio tracks.
Please Help
Thanks in Advance
harishgayatri
harishgayatri is offline
Old 04-07-2009, 11:44 PM   #2 (permalink)
damnbadman666
damngoodman999's Avatar
Default Re: Need to buy PCI Sound Card Budget based
whats the Budget !!
AMD Phenom 2 940 @ 3.4Ghz [Hyper 212+] MA790GP-UD4H OCZ DDR2 2x2GB Asus GTX 560ti 1TB SATA2 LG 20" LED Razer DA mice RED HOT cabby
damngoodman999 is offline
Old 05-07-2009, 12:18 PM   #3 (permalink)
800-1000 bucks
Old 05-07-2009, 02:10 PM   #4 (permalink)
dOm1naTOr's Avatar
there wont be optical or co-axial outs on 1~2k cards.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 06-07-2009, 09:02 AM   #5 (permalink)
Actually dOm1naTOr I did find one but it costs around 2K
Creative Sound Blaster Audigy Value with S/PDIF out as the option.
So anybody has this card. Please comment on it.
Old 06-07-2009, 10:07 AM   #6 (permalink)
dOm1naTOr's Avatar
it seems a good deal. Though the sound blaster audigy isnt gr8 at sound quality, there wont be any degradation in performance by using a digital out and decoding in the home theater system.
which system do you have?
there are lots of mobos with onboard optical/co axial outs. That wud ve saved u 2k and a PCI slot.
G3: XPS M1530 |
FZ 16.
Old 06-07-2009, 08:18 PM   #7 (permalink)
dOm1naTOr are you asking about my home theater system or my PC.
The Home Theater System is SONY DAV DZ-570
and
My PC is an Intel Pentium 4 with D865GBF Mobo Ati HD3650 AGP DDR2 512MB Graphics and SoundMAX Digital Audio with 6 channel support.
Old 28-07-2009, 09:49 PM   #8 (permalink)
Anyway I dont need this got S/PDIF out working as passthrough using my Onboard sound card.
And BTW I reeeeeealy wanted to say Creative is a sh*t, and it also sucks big time.
I does not support linux or Mac.
Stupid Idiots aren't they.
