| Forum |
#1 (permalink) |
#4 (permalink) |
Copied the specs:
AMD X2 4200+ @ Rs. 2600 /- + VAT MSI K9AGM V2 / MSI K9AGM-FD (AMD 780G) @ Rs. 4400 /- + VAT 2 GB DDR-II 667 MHz (Transend / Kingstone) @ Rs. 1850 /- + VAT 160 GB SATA-II 7200.10 (WD / SAMSUNG / Seagete) @ Rs. 1825 /- + VAT DVD RW (IDE - Any brand) @ Rs. 1100 /- + VAT Any local cabinet with default 450 watts SMPS @ Rs. 1200 /- + VAT Is this the best possible combination? |
#6 (permalink) |
X2 4200+ is not available nowadays.
Minimum available is X2 5200+ for 3.2k Biostar 780G mobo: 3.8k or biostar 740G mobo: 3k 2GB transcent/kingston DDR2 800: 1.2k 500GB HDD: 2.8k Samsung 22X SATA DVDRW: 1.2k zebby cabby w 450W PSU: 1.2k
G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518. G2: AII 240 | M2N 68AM+ | 3GB| 8800GT | Zebby Plat 500 G3: XPS M1530 | FZ 16. |
#7 (permalink) |
The Smaller Bang
@Rohit:
Get DOm1naTOr's configuration with the following price updates: Biostar 780G is around 3.3K Then 2GB Transcend DDR2 800MHz RAM for 1K HDD - same price DVD Drive - 1.1K ^^If you bargain properly in SP Road. And yeah, Instead of X2 5200+ try getting Athlon II X2 250 for 4.4K or Phenom II X2 550 for 5.5K. You may have to add 1K or 2K to budget, but these are seriously VFM upgrades you wouldn't regret after an year.
http://TheSmallerBang.wordpress.com eMachines E725 - T4400 2.2GHz, 1GB, 160GB Nokia 5130XM * T-Sonic 610 2GB Nokia 2323C * Samsung Galaxy Y Apple iPad 2 16GB WiFi |
#8 (permalink) |
wow biostar 780g mobo for 3.3 is a gr8 deal.
and yes, AII 250 or PII 550 wud be real improvement over older X2. There is another choice, though not much better than 5200+. Its the X2 7750 BE for 3.3k, which has got L3 cache like the phenoms unlike X2 5200+.
#9 (permalink) | |
The Smaller Bang
Spending 1K more for a better future proof CPU seems worth it.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
