Old 03-07-2009, 07:16 PM   #1 (permalink)
MambaXL's Avatar
Question need confirmation for good [or bad] hardware
Hi,
I have a C2D E6400, on ASUS P5B-VM with 2GB DDR2 667MHz.
I play crysis on XFX GTX 260 [Core 192 - plain vanilla model] with no overclocking, but fan speed at 70%.
I use Vista Home Basic 32-Bit SP1
But, Crysis doesn't seems to play well, both the demo and v1.2.1 when running at all settings very high @ 1680x1050 [no AA]
In nVIDIA control panel, i've set things at
AA - App ctrled
AF - App ctrled
Ambient Occlusion - On
I get around 20 fps
Is it okay, or is there any problem with my hardware?
PSU - Corsair VX450W
Driver - 186.18
I also have CS:Source , it caps at around 180 fps.
Please suggest something..
MambaXL is offline
Old 03-07-2009, 08:43 PM   #2 (permalink)
Default Re: need confirmation for good [or bad] hardware
change your processor
get quad core
raj_v1982 is offline
Old 05-07-2009, 12:57 PM   #3 (permalink)
The Boss
aytus's Avatar
Ur RAM is too little and too slow.. get atleast 4GB running at atleast 800MHz.
G3N10U5 BY B1RTH, HACK3R BY CH01C3
E5200; Biostar P43-A7; Palit GF 9600GT; Corsair 4GB; CM extreme power 390W
aytus is offline
Old 05-07-2009, 02:40 PM   #4 (permalink)
15.0 GHz
VarDOS's Avatar
yes proccy seems to be quite old, change it to quad-core as u r mobo is quadcore ready, i suggest go for Q8200.
About RAM 2GB is more than enough if u r Game uses the Video Ram more than the RAM, 2GB is ok
iPod Touch 4th Generation - 64GB
VarDOS is offline
Old 05-07-2009, 04:03 PM   #5 (permalink)
Ethan_Hunt's Avatar
I play @1280x1024 with everything on high & get 35-38fps on my system. So no, 4GB is not mandated.
@OP: Disable Ambient Occlusion. It's not necessary at all. A lot of games take a massive hit when this setting is enabled. Your card should easily deliver more fps. Also try applying Cuban-Ultima-Doom-Sword's Custom Crysis Config [CCC] Tweak v1.3
V for Vendetta
Ethan_Hunt is offline
Old 05-07-2009, 04:43 PM   #6 (permalink)
MambaXL's Avatar
Well, I cant afford to get a quad core now, coz I am saving for a Core i5 . I just want to know, is my hardware ageing, or its OK ?
Anyway thanks for the info guys..
MambaXL is offline
Old 05-07-2009, 04:48 PM   #7 (permalink)
MambaXL's Avatar
Thnx, I'll look into the config tweak.
btw, with Ambient Occlusion, I dont see any graphical wonders, and my games dont perform badly either. I mean, i dont see any difference, if its disabled, or enabled. Whats your take on this ?
MambaXL is offline
Old 05-07-2009, 06:30 PM   #8 (permalink)
Ethan_Hunt's Avatar
I'm not sure about Nvidia cards, but my ATI card takes a huge hit when I enable this setting. Games like Saints Row 2 & The Chronicles of Riddick: Assault on Dark Athena are among those which lower my fps dramatically once this setting is enabled. Saints Row 2 is almost rendered unplayable. If it isn't making any difference for you then it's your call on activating it.
V for Vendetta
