Old 02-07-2009, 11:03 PM   #1 (permalink)
Dishant's Avatar
Cool suggestion reg. wireless kb+mouse & Dvd Writer
hi guys;
1.I want to purchase keyboard + mouse . my preference is wireless combo . i am thinking of iball 2.4 GHz Cordless Couple but not sure if it's a good choice . my maximum budget is Rs.2000. Another thing i want to ask is that are wireless kb and mouse better than the wired ones .pls suggest good kb +mouse. ............
2. Also i need suggestions for a good DVD Writer.I'm sucked of buying a new Drive every year.pls help guys.....thanks
Dishant is offline
Old 03-07-2009, 01:02 AM   #2 (permalink)
Default Re: suggestion reg. wireless kb+mouse & Dvd Writer
Don't go for iBall 2.4 Ghz. combo. I used the combo for about 8 months after which keyboard keys started getting stuck and hard, I didn't even used the keyboard for heavy typing or heavy use. The mouse that comes with the combo is really good and i use it on regular basis also would like you to suggest to go in for wired keyboard (any will do) and good wireless mouse like iball cordless 2.4 Ghz. (mouse only) or logitech as you can control everything like media player etc. with mouse only.
hemantpl is offline
Old 03-07-2009, 01:08 AM   #3 (permalink)
Google Bot
Pathik's Avatar
1. Microsoft Wireless Optical Desktop 1000.
2. Samsung SH223S 22X DVDRW
Pathik is offline
