| Forum |
#1 (permalink) |
and motherboard temp for both Zone 1 & 2 fluctuate between 45-50. 2 is allways 2-3 degree Higher. |
#3 (permalink) |
Tech addict
No these temps are above normal so make efforts to pull them down. Take clues from this thread to how to lower the temperature of your processor.
is 60 C cpu temp. too hot?
C2D E7300,ASUS P5KPL-CM, 2x2GB 800MHZ DDR2, XFX GTX260 core 216 BE, CREATIVE X-FI XTREME GAMER,WD 1.5TB X2 HDDs,ANTEC EA-650w,LOGITECH Z5500, BENQ T2200HD+LG 42" LCD Scarlett 2.0,Iball cordless couple |
#6 (permalink) | |
mera kutch nahi ho sakta
jin files ka koi server nahi hota unka bittorrent hota hai Last edited by chesss; 02-07-2009 at 10:33 PM. |
#8 (permalink) |
dust can cause incorrect speed sensing. Clean off the dust.
G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518. G2: AII 240 | M2N 68AM+ | 3GB| 8800GT | Zebby Plat 500 G3: XPS M1530 | FZ 16. |
#9 (permalink) |
that speed is normal.
whenever my CPU crosses 50C the fans spins at 3k.
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90 |
#10 (permalink) |
Double Post!
#12 (permalink) |
CPU temp can be reduced by arround 10 C with good ventilation. A good rear exhaust fan and side intake fan can do wonders with CPU temp. My E5200 CPU has around 35 C idle temp and 48 C at full load.
#13 (permalink) | |
damnbadman666
AMD Phenom 2 940 @ 3.4Ghz [Hyper 212+] ![]() |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
