Old 01-07-2009, 08:36 PM   #1 (permalink)
Default where can i buy cheapest 80mm or 120mm casing fan?
I am from mumbai want to buy cheapest 80 and 120 mm casing fan where can i get? i dont need brand.......but should work..also what is the price?
ashray99923 is offline
Old 01-07-2009, 10:02 PM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: where can i buy cheapest 80mm or 120mm casing fan?
local ones shudnt cost u more than 100 bucks for a 120mm one and 50~60 bucks for 80mm ones.
just go to a PC shop, or PC accessory shop.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
