Old 01-07-2009, 02:32 PM   #1 (permalink)
Google Bot
Pathik's Avatar
Default New PC Suggestions! HALP!
Guys, I need to get a new PC in 25k.
Here's what I have thought of so far-
Intel Dual Core 2.5 GHz E5200 - 3375
Gigabyte GA-G41M-ES2H - 3350
Corsair DDR 2 CM2X2048-6400C5 - 1550
Western Digital 1 TB SATA HDD 32 MB Buffer - 4500
Samsung 933SN 18.5" LCD - 6900
Altec Lansing BXR1120 2.0 Speakers - 650 OR Creative SBS 245 - 500
Logitech / MS Mouse + Keyboard - 700
Zebronics Bijli / Aroma + 400W PSU - 1650/1100
I've also considered
Gigabyte GA-MA78GM-S2HP AMD 780G+SB700 - 4775
AND
Athlon 64 X2 7750+ BE 2.7GHz 3MB L2 - 3575
instead of the Intel combo and am still divided between the two.
E5200 overclocks better than the 7750BE but 780G is luring me towards the AMD combo.
But maybe I will get a better mobo in about 6-7 months and a graphic card as well.
Also AMD - 8350 and Intel combo - 6725 so am planning to go with the Intel combo only.
Maybe instead of both, I could get a Gigabyte G31 for 2400 and E5200 for 3375 and a Palit 9400GT
512 MB for 2400. That works out to be 8100, cheaper than the AMD combo. What say?
Comment on this. Thanks.
Prices from theitwares.com
Pathik is offline
Old 01-07-2009, 06:37 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: New PC Suggestions! HALP!
Intel Dual Core 2.5 GHz E5200 - 3450
Asus P5KPL-CM/E - 2425
Corsair TWIN2X4096-6400C5 (2 X 2GB)- 3150
Dell 1909 19" LCD - 7200
Altec Lansing BXR1120 2.0 Speakers - 800
Samsung 22X SATA SH-223F DVD RW - 1200
Zotac 9400GT 512 MB - 2500
Zebronics Bijli + 400W PSU - 1650
Total: ~26k.
This is what I am getting mostly. Any suggestions?
Pathik is offline
Old 01-07-2009, 07:22 PM   #3 (permalink)
i would suggest
If looking for on board GFX try (also it will be a HELL LOT OF POWER MACHINE)
The new
Phenom II x2 550
Gigabyte 780g us2h / biostar 790 Mobo..
Phenom will be a good overclocker can check websites
http://www.thinkdigit.com/forum/show...postcount=6463
I personally opt for E5200 + G31 (DES version) + any stupid gfx card (depends on usage)
Just because of Power consumption is known
blackbird is offline
Old 01-07-2009, 07:24 PM   #4 (permalink)
Point Blanc
Gigabyte GA-G41M-ES2H - 3350 , nice pricing for the mobo.
If you have to run your system for very very long hours get the intel, its more energy efficient, otherwise allway for the AMD config, better mobo in lesser price.
instead of 9400GT check HD4350
acewin is offline
Old 01-07-2009, 08:32 PM   #5 (permalink)
j1n M@tt's Avatar
my suggestion :
Dual Core E5200
Asus P5KPL-E(but I don't think it is 2.4k)
Transcend JetRam 2x2GB 800MHz@2.4k(overclocks a lot better than Corsair XMS2 kit)
AOC 917Fwx XHD 19" LCD@6.8-7k or Samsung 2033SW 20" LCD@7.5k
Altec Lancing BXR 1121 2.1 speakers@1.2-1.3k or Logitech X210 @1.5k
rest as u hav posted...wait for sometime and make budget for a gud mid range grfx card
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 01-07-2009, 08:56 PM   #6 (permalink)
Google Bot
Pathik's Avatar
Okie, will get Transcend Jetram then.
How's the AOC 22'' 2216 SW for 9.4k? And are there any problems with the Dell 1909?
@blackbird, will check it out as well.
Pathik is offline
Old 01-07-2009, 09:08 PM   #7 (permalink)
Google Bot
Pathik's Avatar
^ Do all batches of Phenom II X2 550 have unlockable cores? Or only the old ones?
Pathik is offline
Old 01-07-2009, 09:10 PM   #8 (permalink)
in my view dear dont go for amd pros k,,, it's my own experience after seing around 4-5 hundred systems theat they heat up quickly and then lead to disasters.. go for latest highest end intel pro ,,, in ur budget
t_rex17 is offline
Old 01-07-2009, 09:31 PM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@t_rex17. ROFLMAO.
that means you are not installing them in proper way. Why didn't my AMD processor Athlon 64 heat up even after 3yrs of 500MHz overclocking and gaming.
Clearly, finger points to you. Learn how to install processor and then talk!!!!
desiibond is offline
Old 01-07-2009, 09:36 PM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
First 7750BE is really bad in overclocking.
Second, yes 780G is tempting and you can get similar performance with G31+9500GT.
Dell 1909 is very good model, but as per latest updates, Dell is not shipping monitors to India it seems. Check with Dell. A 22" will have definite advantage and is worth the extra 2k (over 19")
Old 01-07-2009, 09:52 PM   #11 (permalink)
j1n M@tt's Avatar
AOC F22 Fovi is a gud model and similar to Samsung 2233SW in performance, but looks damn cool
ya all PII 550BE hav 2 cores hidden but we can't guess whether they are defective ones or gud ones...it's all about luck, same with E5200..not all of these chips are good OC'ers.
j1n M@tt is offline
Old 04-07-2009, 10:59 PM   #12 (permalink)
Take a look at Benq2412HD - under 13k 23.6" monitor full hd resolution. Else E2200HD around 9k - fullHD.
Buy Q8200/ E5200 / E7300 (depending upon ur budget).
Motherboard - Gigabyte GA-G41M-ES2H - just because its ATX. And most others are micro-atx.
RAM - any 800mhz RAM
HDD - my choice would be Seagate 7200.11 1 TB
video card - 9600GT PALIT
Intel D930&945GNTL| 2x1GB 667 Mhz(Transcend+Kingston)| 500GBSeagate+200 GB WD|Zotac 9600GT Amp!| Zebronics Platinum 400W|Dell SP2208WFP|Logitech z5500| Lite-onDVD-RW+LGDVD-R
emmarbee is offline
Old 04-07-2009, 11:54 PM   #13 (permalink)
damnbadman666
damngoodman999's Avatar
AMD PII 550 - ( We can unlock with the new models )
Gigabyte MA78GM-US2H / Biostar 790gx - 4.8K (BTW biostar i never trust - but its used to unlock the cores )
Transcend Jetram
WD 1TB
AOC F22 Fovi (also) look for Benq G2220HD (But considering samsung /Dell will good in quality )
The rest is ur wish !!
AMD Phenom 2 940 @ 3.4Ghz [Hyper 212+] MA790GP-UD4H OCZ DDR2 2x2GB Asus GTX 560ti 1TB SATA2 LG 20" LED Razer DA mice RED HOT cabby
damngoodman999 is offline
Old 10-07-2009, 02:42 PM   #14 (permalink)
hi
what's ur budhet for the pc u wanna purchase.?
t_rex17 is offline
Old 10-07-2009, 02:47 PM   #15 (permalink)
dnt go for amd dude after all ne how dnt go...
t_rex17 is offline
Old 10-07-2009, 02:50 PM   #16 (permalink)
BSD init pwns System V
hellknight's Avatar
@t_rex17.. you might wanna check out the SHOW OFF thread in the Chit-Chat section where I overclocked AMD 720 BE processor upto 3.6 GHz from 2.8 GHz and the temperature was around 43 degrees celcius.. and you really need to update your views on AMD processors..
@pathik bhai...
AMD Phenom II 550 BE is THE BEST in your budget..
Biostar TA790GXBE and if you want crossfire then Jetway HA 07 Ultra (the best)
and AOC F22 LCD (i'm loving it, its a looker) for 9.5k only, 1080p res...
Good luck on unlocking the cores.. you might wanna research the internet on that.. go for ASRock board.. Tomshardware has a nice review of that board and unlocking the cores using it.. search for it..
My blog :- www.openenclave.wordpress.com
hellknight is offline
Old 10-07-2009, 02:53 PM   #17 (permalink)
hellknight's Avatar
Here you go.. this is the page which might help you in unlocking the cores....
Old 10-07-2009, 07:13 PM   #18 (permalink)
j1n M@tt's Avatar
the new BIOS doesn't support unlocking of cores...hav to use old BIOS version if needed to unlock them
j1n M@tt is offline
Old 13-07-2009, 12:44 PM   #19 (permalink)
Point Blanc
and much better choice than biostar mobo.
acewin is offline
Old 19-07-2009, 12:13 PM   #20 (permalink)
rohit2hell's Avatar
iam an Animation student and wants to buy a CPU can any one guide me please.. i have budget 45K
rohit2hell is offline
Old 19-07-2009, 01:37 PM   #21 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@rohit2hell,
wait till first week of August for AMD 785G ddr3 motherboard.
Old 19-07-2009, 01:43 PM   #22 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
try to go with phenom2 x2 550.....if it is out of your budget
go with athlon x2 250....
this is what i'd suggest
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ssk_the_gr8 is offline
Old 19-07-2009, 05:01 PM   #23 (permalink)
rohit2hell's Avatar
thanks for reply guys bt.......... i have 45,000 Rs and wants to buy :
amd proceesor - ?
motherborad - ?
ram - ?
500Gb HDD - ?
graphic card - ?
DVD drive - ?
power supply - ?
Help me
Thanks in advance...
Old 19-07-2009, 07:17 PM   #24 (permalink)
Bond, Desi Bond!
desiibond's Avatar
amd proceesor - ?
motherborad - ?
ram - ?
500Gb HDD - ?
graphic card - ?
DVD drive - ?
power supply - ?
Help me
wait for 2 more weeks for release of AMD 785G ddr3 am3 board. else go for this:
amd proceesor - Phenom II X4 940
motherborad - ASUS M4A78-EM
ram - 2x2Gb DDR2 800MHz Corsair XMS2
500Gb HDD - Seagate 7200.12 or Western Digital Caviar Blue/Green
graphic card - Powercolor HD4870or Palit GTS250
DVD drive - samsung
power supply - Corsair VX550W or GlacialPower 650AA 650W
Old 19-07-2009, 08:07 PM   #25 (permalink)
rohit2hell's Avatar
Which is better ???
HD4870 (512mb-DDR5) or Crossfire HD4670 (2GB-DDR3)
Old 19-07-2009, 08:09 PM   #26 (permalink)
rohit2hell's Avatar
Which is better ???
Old 19-07-2009, 08:16 PM   #27 (permalink)
Point Blanc
what else u wanna buy. , do you have any Hardware with you.
wait for some more time and you will realize it was a wise move.
if u wanna go quick then
gigabyte/msi AM3 board based on amd 770 chipset with SB710 southbridge.
proccy phenom II 550 BE
2GB DDR3 RAM from transcend.
hdd as much u want.
burner any you like
dell monitor S2409/S2209 or samsung S2233SW
psu CX450,
gfx nVidia GTX250/HD4850/HD4870, try to get more VRAM than just best card.
HD4870 is better than HD4670 crossfire.
take a look into this thread for more cards and prices to make your choiceLatest Prices by comp@ddict
acewin is offline
Old 19-07-2009, 08:18 PM   #28 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@rohit, HD4870 is lot lot better.
Old 19-07-2009, 08:31 PM   #29 (permalink)
Point Blanc
actually almost thrice if I am not wrong. and to do crossfire u need crossfire mobo too,
and yeah correction for the PSU VX550.
acewin is offline
Old 20-07-2009, 06:14 PM   #30 (permalink)
rohit2hell's Avatar
iam planning to take these... is this a good choice??
Processor- AMD phenom II 955 BE
Mothrboard - Asus M4A
Ram - Transcend 2X2 Gb (DDR 3 Speed-1333)
Graphic card - XFX HD4870 (512 mb DDR5)
Power Supply - Cooler master 600W
HDD - 500 Gb Seagate
Rom- Samsung 22x
Help me...
And suggest me a Cabinet worth Rs 2K
