Old 20-07-2009, 06:24 PM   #31 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: New PC Suggestions! HALP!
M4A??? which model. m4a78-EM is still a ddr2 board.
anyways wait for 785G chipset based boards. should arrive in two weeks time.
desiibond is offline
Old 20-07-2009, 07:52 PM   #32 (permalink)
Google Bot
Pathik's Avatar
Guys, got the PC.
BTW does anyone here have a Asus P5K PL CM? My built in Via sound card isn't working in Vista 64 bit. Any ideas?
Even the Vista standard drivers don't seem to work.
Pathik is offline
Old 20-07-2009, 08:13 PM   #33 (permalink)
Google Bot
Pathik's Avatar
^ Ignore this. A fresh install of audio drivers did it.
Pathik is offline
Old 21-07-2009, 07:42 AM   #34 (permalink)
rohit2hell's Avatar
its M4A78T-E (model uses the 790GX chipset) its a AM3 Socket
What to do??? Should i buy this config ???
Processor- AMD phenom II 955 BE
Mothrboard - Asus M4A78T-E
Ram - Transcend 2X2 Gb (DDR 3 Speed-1333)
Graphic card - XFX HD4870 (512 mb DDR5)
Power Supply - Cooler master 600W
HDD - 500 Gb Seagate
Rom- Samsung DVD-RW 22x
Help me...
And suggest me a Cabinet worth Rs 2000
rohit2hell is offline
Old 21-07-2009, 09:04 AM   #35 (permalink)
Bond, Desi Bond!
desiibond's Avatar
go for Cooler Master Elite 330 for 2k (if you can find it) else Zebronics Reaper without PSU for less than 2k.
What is the price of M4A78T-E BTW? It's a pretty good board and worth only if you can get it inside 9k. And if you are not going to use Crossfire, you better get a cheaper 770G board or wait for 785G motherboards.
I wouldn't suggest the entry level Transcend DDR3 if you are going to overclock the RAM and when you do CPU overclocking (by increasing HT speed), you may have to downclock the RAM frequency to keep it stable (which is not a big thing anyways)
Old 22-07-2009, 05:39 PM   #36 (permalink)
rohit2hell's Avatar
M4A78T-E costing me about 9700
im planning to get 1 HD 4870(512 mb DDR5)
Old 26-07-2009, 02:21 AM   #37 (permalink)
Gutz...i need to buy a new laptop around 35000...can u suggest something??/plz reply asap...
sumanta4u is offline
Old 26-07-2009, 10:36 AM   #38 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@roghit, how about gettting mobo worth 5k and put that extra 4k into GPU??
- by ax3
