Old 01-07-2009, 11:18 AM   #1 (permalink)
Default Internet Trobuleshooting
I Got a Tata indicom Photan plus But there is problem when i start the connection after 3 mints i get error reports that is Generic host. like Generic host process for win32 services.
Generic host process for win32 service has encountered a problem and need to close.
how i can solve this prob. plz. help me.
sonmani is offline
Old 01-07-2009, 12:59 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: Internet Trobulescooting
hope this helps
1.) http://www.experts-exchange.com/Oper..._20867724.html
2.) http://www.windowsbbs.com/malware-vi...eds-close.html
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 01-07-2009, 01:31 PM   #3 (permalink)
Say no more. Get on floor
vamsi_krishna's Avatar
I smell sort of virus or malware attack. Consider full system scan with a updated antivirus or go for system restore.
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is offline
Old 01-07-2009, 01:37 PM   #4 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Check this too: http://answers.yahoo.com/question/in...0000642AAUF4XI
ASUS K42JA-VX032D RAWKS !!!!!!
Disc_Junkie is offline
Old 01-07-2009, 03:21 PM   #5 (permalink)
paroh's Avatar
I decided to write this entry for the sake of those ppl who want to get their computer back to normal. All you’ve got to do is to close port 135 and 445. So here’s what you’ve got to do:
How to close port 445
Start Registry Editor (Regedit.exe) by clicking Start menu, and then click the Run icon.
In the small box that Opens, type: regedit then click the OK button.
The Registry Editor will now have opened…
Locate the following key in the registry:
HKLM\System\CurrentControlSet\Services\NetBT\Param eters
In the right-hand side of the window find an option called TransportBindName.
Double click that value, and then delete the default value, thus giving it a blank value.
The you must now navigate to the following registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\OLE
You will see there is a String Value called: EnableDCOM
Set the value to: N (it should currently be Y)
Close the Registry Editor.
Shutdown and Restart your computer.
You could also disabled NETbios. But I’ve found that by disabling these two, my computer get back to normal without re-formatting my computer etc. Hope you can get rid of this faulting application “svchost exe” problem. Good Luck!!
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
paroh is offline
