Originally Posted by prabhu.wali
hi,
i plugged all the connecting cables to clean ma pc hardware
Do you mean that you UNplugged everything?
n after plugging i not able to gwt any display on the screeen
Do you mean that you reconnected everything?
n also i restarted after unplugging ram theres no beep but cpu n graphic are workin as normal. please help
If you're not getting any display, how can you say that your CPU and graphics card are working? Do you mean that the fans are spinning? Spinning fans don't necessarily mean that the devices are working.
It's very likely that there's something you did not reconnect properly. Carefully check all connections, make sure they all fit firmly. It will be better to pull them out and then re-insert them again firmly. Then try again.
It will be best to leave the hard disk unconnected until you get a proper display again.
