Old 01-07-2009, 06:35 AM   #1 (permalink)
hskpunjabi's Avatar
Exclamation need UPS which brand??
hi friends .,i need ups for my system(P4 + 17'' monitor)which one is better iball or some other ....price counts... budget is b/w 1.5-2k
can it work with my home inverter??
((it gives backup to system but restarts when monitor is switched on/laptops work fine....n' no instant back up as light goes off pc restarts ))
hskpunjabi is offline
Old 01-07-2009, 07:11 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: need UPS which brand??
APC. nothing else!!!
desiibond is offline
Old 01-07-2009, 07:18 AM   #3 (permalink)
hskpunjabi's Avatar
thanks bro!
how is Apc better? price range??
Old 01-07-2009, 09:20 AM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
1) Reliable
2) Great support infrastructure
3) price for a 650VA should be around 3.2k
Don't go for those iballs and mercurys for UPS. they suck and very soon you will see issues (battery of power switching)
Old 01-07-2009, 10:00 AM   #5 (permalink)
Super Moderator
asingh's Avatar
APC..is great...was using a 650VA before, just got a 1100VA. Excellent.
650VA even has monitoring software via USB connection.
asingh is offline
Old 01-07-2009, 11:43 AM   #6 (permalink)
a.k.a VipER
Ecstasy's Avatar
I used to use APC until now, the only problem with it is that its costly. I bought my new computer and now I'm using I-ball. It works great and its cheap as well compared to APC.
Originally Posted by shayanthebest View Post
I want to buy a new computer which can play 2-3 year old games at good resolutions. My budget is 5 to 6 lakhs. Please help
Ecstasy is offline
Old 01-07-2009, 12:57 PM   #7 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
APC all the way,
i hv 2 UPS from APC (APC BACK UPS ES500 and APC SMART UPS SUA 1500i) , go with APC for complete peace of mind dude.. its worth tat extra bucks..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 01-07-2009, 01:41 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
true. I fell for the same cheap crap called Mercury and after few weeks it started malfunctioning. now using APC 500VA and have peace of mind.
Old 04-07-2009, 05:34 PM   #9 (permalink)
!0 days back, I purchased a Moserbaer UPS A600. Working nicely, with
frequent powercuts here in Chennai.
vsrini40 is offline
Old 04-07-2009, 05:38 PM   #10 (permalink)
damnbadman666
damngoodman999's Avatar
Moserbaer UPS A600
how much ???
AMD Phenom 2 940 @ 3.4Ghz [Hyper 212+] MA790GP-UD4H OCZ DDR2 2x2GB Asus GTX 560ti 1TB SATA2 LG 20" LED Razer DA mice RED HOT cabby
damngoodman999 is offline
Old 04-07-2009, 05:50 PM   #11 (permalink)
I M A *STAR*
saqib_khan's Avatar
Anybody used Powersafe UPS? Hows it
Stealth mode, I like that. Kool.
Blogging at:
A Techies Blog
saqib_khan is offline
Old 04-07-2009, 10:08 PM   #12 (permalink)
I've been recommending Microtek Double Battery to all my friends. And i like that very much. It has got long time backup.
Tested:
D930 processor + 945GNTL + samsung 173N (17" flat) + fifa game running on demo --> lasted for more than 30 mins on that battery.
I'm using the 800va i guess - u might opt for a lower one if ur pc is budget one with lower end video cards.
Of course, I've got some problems with it.
1) A brand new microtek UPS didn't give backup; It restarts the PC when there is a sudden power change. But if it is switched off, it'll work. I got it replaced.
2) The replaced one (after about an year) is giving the same problem again. Its not able to withstand the power requirements of my PC. I 'll replace it soon . . .
Intel D930&945GNTL| 2x1GB 667 Mhz(Transcend+Kingston)| 500GBSeagate+200 GB WD|Zotac 9600GT Amp!| Zebronics Platinum 400W|Dell SP2208WFP|Logitech z5500| Lite-onDVD-RW+LGDVD-R
emmarbee is offline
Old 05-07-2009, 11:53 AM   #13 (permalink)
Tested:
I bought same microtek double battery 800 VA UPS 18 months back. Its running good. I have decently loaded PC with 2 HDD , and 9600 GT and and couple od 120 mm fans.
jeetu is offline
Old 05-07-2009, 11:57 AM   #14 (permalink)
damnbadman666
I used Microtek 800VA double power its good , but when u update the PSU with Active PFC then the uPS is waste !!
Try to Get APC which is really good !!
Old 05-07-2009, 12:08 PM   #15 (permalink)
[QUOTE=damngoodman999;1138150]I used Microtek 800VA double power its good , but when u update the PSU with Active PFC then the uPS is waste !!QUOTE]
Could you elaborate on that because recently i bought Cooler master Real Power Pro 660 W . It has active PFC.
jeetu is offline
Old 05-07-2009, 01:10 PM   #16 (permalink)
an ACTIVE PFC PSU needs (and its is a must) a PURE SINE WAVE UPS..
APC's SMART UPS range of UPSes are pure sine wave UPS and ideal for ACTIVE PFC PSUes..
but... PURE SINE WAVE UPSes are way too costly than normal (Stepped/modified) sine wave UPSes and it is NOT recommended to use a stepped/modified sine wave ups for a ACTIVE PFC PSU as in future it will cause:
mobo unstability, "hiss..ss..ing" noises from the PSU (as if the psu is not able to draw full power), system unstability issues..
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 05-07-2009, 01:59 PM   #17 (permalink)
damnbadman666
U can use Square wave UPS also but u need sufficient watts to draw power from the UPS also better backup , Iam using APC1100va which is not Sine wave but the buzz sound comes but nothing problem , all u need is enough power
Old 06-07-2009, 12:03 AM   #18 (permalink)
yup agreed..
the hissing noise or any other problem are jus some of the problems faced by users adn its not fixed on all PCs.. hope u got the point..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 06-07-2009, 12:45 AM   #19 (permalink)
damnbadman666
Corsair support had told me its a Coil buzz , no need to worry about anything !!
Old 06-07-2009, 01:01 AM   #20 (permalink)
ooh isee..
offtopic: see my rigs (yup, u read it right) in the SHOWOFF thread..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 06-07-2009, 11:53 AM   #21 (permalink)
APC.....if ur budget doesn't fit .......................
Go for "NUMERIC".....reliable ups.
ksundar is offline
Old 06-07-2009, 12:00 PM   #22 (permalink)
Whats the price to 800 VA APC Sine wave UPS ?. So far i have heard no hissing noise but still its better to be careful then sorry.
jeetu is offline
Old 06-07-2009, 01:16 PM   #23 (permalink)
i think it will cost u near about 7.5-8K
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 06-07-2009, 02:44 PM   #24 (permalink)
Super Moderator
asingh's Avatar
i get the same... worried now..for like 4-5 seconds..when I power it on...!
asingh is offline
Old 06-07-2009, 02:53 PM   #25 (permalink)
damnbadman666
^^ Its nothing !! corsair dint not recommend to use sine wave with their PSu , though the PSU can convert voltage fluctuations to normal
Corsair warranty is really amazing that they give warranty if any damages caused by UPS - they said that no chance of damages due to square wave !!
Old 06-07-2009, 03:20 PM   #26 (permalink)
Super Moderator
asingh's Avatar
Great thanks...love Corsair..!
Though -- not doubting you...where exactly did we hear/read that Corsair PSU need pure sine wave..is there any documentation..links..?
asingh is offline
Old 06-07-2009, 10:35 PM   #27 (permalink)
wait, i remember reading such a doc online, but alas i dnt hv the link.. but yes wil surely post the source in a day or 2, promise.. (maybe i'll take an extract from corsair forums and post the link too)
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 06-07-2009, 10:42 PM   #28 (permalink)
see this --> Buzzing noise from PSU (Corsair forums) --_> http://forum.corsair.com/v3/showthread.php?t=75330
also, read the Q.#4) about Active PFC, all Corsair HX PSUes are Active PFCs ---> http://forum.corsair.com/v3/showthread.php?t=52589
and here are the reviews of various Corsair PSUs (Sorry, jus posting links) hope u guys will be able to find ur PSU model here --> http://forum.corsair.com/v3/showthread.php?t=52612
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 08-07-2009, 10:40 AM   #29 (permalink)
Super Moderator
asingh's Avatar
Cheers n e-peace...
Hey thanks a lot for this. First thread is interesting. Will try those changes, and post back here. The 2nd two are good and informative.
asingh is offline
Old 08-07-2009, 12:16 PM   #30 (permalink)
Dust in the Wind
Skud's Avatar
i have a apc 500va ups but it's backup is very poor just 1-2 minutes. my machine config is c2d e7400, hd4850 512mb, ddr2 800, seagate 500gb and 2 250gb external drives along with cm 600watt psu.
what's the problem?
Skud is offline
