Old 10-07-2009, 12:28 PM   #61 (permalink)
Hanging, since 2004..
tarey_g's Avatar
Default Re: need UPS which brand??
Price of 650/800 Smart/Back ?
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is online now
Old 10-07-2009, 12:38 PM   #62 (permalink)
Super Moderator
asingh's Avatar
Originally Posted by maverick786us View Post
Great. From where you purchased it? I purchased an 800VA for 5200 last year september
Pretty strange its still costing 5400 in TheItWares
http://www.theitwares.com/ups/ups.htm
This is the one I got. I got it from a shop in Nehru Place. Can get you the exact name once I get back home.
Originally Posted by tarey_g View Post
What is the product code or full name for the APC 650VA UPS ? 650 fits in my budget. Does 800 one have anything special other than extended backup?
This is the link for the 650VA.
This is the link for the 800VA. And this too.
When getting a UPS make sure you check the max throughput WATT support (efficiency) it gives.
1100VA:660W
800VA: 500W
650VA: 390W
The rule of thumb to calculate efficiency is ~60% of the VA rating. VA is volts into amps which equals WATTS. P = VA. So we may ask, if the UPS is rated at 1100VA why cannot the UPS support 1100W of equipment. Reason being energy conversion. There will be a loss of energy (and in our case ~ 40%). All electronic components have a resistance, which cause the loss in energy --- where does that energy go...well we 'feel' it as heat. The UPS getting hot...!
Basically when planning the UPS:
1. Max system requirement during load: MaxRequired
2. Max UPS efficiency watt output: UPSOutput
3. UpsOutput = MaxRequired + 30% of MaxRequied
This way you will be future scaled..
asingh is offline
Old 10-07-2009, 12:56 PM   #63 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
^^ hey asigh thanx a lot yaar for tat UPS buying tip..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 10-07-2009, 03:00 PM   #64 (permalink)
Dust in the Wind
Skud's Avatar
Originally Posted by ashu888ashu888 View Post
@ skud:
if ur PSU is an ACTIVE PFC type, then u shud get "SMART UPS" (pure sine wave UPS, correct for Active PFC PSUes) labelled UPS from APC and NOT "BACK UPS" (its stepped/modified sine wave UPS and a big no no for Active PFC PSU, if u are looking for a pure sine wave)
my psu is cooler master RS-600-PCAR-E3 (or may be 650, can't remember properly). don't know if it's an active pfc type or not. plz comment.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline
Old 10-07-2009, 03:16 PM   #65 (permalink)
Super Moderator
asingh's Avatar
Here you go.
7th line in the specifications sections.
asingh is offline
Old 10-07-2009, 03:47 PM   #66 (permalink)
Dust in the Wind
Skud's Avatar
@ asigh
thanks mate. u guys r really wonderful.
Gaming Rig:
HTPC Rig:
Skud is offline
Old 14-07-2009, 07:08 PM   #67 (permalink)
Originally Posted by damngoodman999 View Post
how much ???
Sorry for the delay. It was Rs.1800/- Working nicely.
vsrini40 is offline
Old 18-07-2009, 01:02 AM   #68 (permalink)
Point Blanc
@asigh, what is the running time for the backup UPS u got the 1100VA one,
my dad had bought this intex UPS for home and it is giving quiet a trouble now, it certainly would be quiet old too 2 years or so, not sure. if it gives me 30 mins of time it will be quiet good
config is
Bestec 300W PSU(70% performance)(not able to do anymore upgrades of HDD or gfx card due to this PSU, so just waiting for time to buy new PC)
Pentium D 820
2 SATA HDDs
DVD Burner
Beside these I run my ADSL router too attached in, in short long run time will be useful, as here in bangalore electricity is cut 2-3 times daily at fixed timings.
acewin is offline
Old 18-07-2009, 09:55 AM   #69 (permalink)
Using apc my self for 6 yrs now , only battery change so far , and need no drivers to get connected to pc (win based)
Only APC please , Help line ROCKS
www.LiveGlamour.com
eureca_eureca is offline
Old 19-07-2009, 04:22 PM   #70 (permalink)
Super Moderator
asingh's Avatar
config is
Pentium D 820
2 SATA HDDs
DVD Burner
Backup:
LOAD : 5-6 mins.
IDLE : 18-20 mins.
Max Throughput: ~660W
asingh is offline
Old 20-07-2009, 11:54 AM   #71 (permalink)
for better wefficiency and back up time, the VA rating of the UPS (60%) shud corellate to the wattage of the PSU..
since u hv a 600W PSU, and a 500VA UPS, so 500VA x 60% (i.e 500 X 0.6 = 300W) and ur PSU is 600 W so therefore the reduced back up time..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 20-07-2009, 05:51 PM   #72 (permalink)
reniarahim1's Avatar
My UPS is also gone and I have decided to go for a new APC One. I would be connecting 19" Dell LCD , CPU(P4+845 Motherboard+Hard Disk+DVD Writer) and Broadband Modem to the UPS. Will a 500VA Will do Or Do i need to go for 650 VA one?
Wats the current cost of APC ES 500VA and APC ES 650VA?
reniarahim1 is offline
Old 20-07-2009, 06:25 PM   #73 (permalink)
Bond, Desi Bond!
desiibond's Avatar
hmm. depends on the UPS. anyways ,go for 650VA or 800VA as the more it is, the better it would be.
desiibond is offline
Old 20-07-2009, 10:13 PM   #74 (permalink)
Super Moderator
asingh's Avatar
Guys..if you read..here it is for APC: (its mentioned a couple of posts above)
1100VA:660W
800VA: 500W
650VA: 390W
Also as desibond has mentioned...throughput is ~60% of rated VA.
As for calculating Wattage Requirement:
Approximate figures would be: (LOAD)
Monitor : 30W (irrespective of load/idle)
Intell 45nm processor: 65W. Intel details can be sought here. You can directly type your model (example E7400) in the search bar, and get the Wattage).
RAM: 10-12W per module.
HDD: 12-15W per disc.
GPU: Depends -- check the review websites. Make sure sure you get the power draw 'only' for the GPU -- and not the whole system, it would obviously be different to your own setup. This is a major factor when deciding Power Requirements. High end cards (4870, 4890 GTX 275, GTX 285, in fact even nVidia GS series, HD4850 series require a lot of power at load).
Note for SLI/X-Fire:
Be extremelly careful, when buying PSU/UPS. With a 'normal' setup you can "live on the edge", meaning--you can have a UPS which matches exactly the PSU requirements and be safe. With multi-GPU it becomes really dynamic, cause the cards cause a lot of variation in system power pull. At times one is scaling, or both will...very sensitive.
Calculate your Wattage (on the upper limit -- meaning take the upper limit if you got to approximagte add 30% to the number you get). That should be your UPS requirement.
Also this is a good tool -- to get the ballpark figure.
Or another way to calulate it --- much simpler.
UPS = PSU Rating + 30% of PSU Rating.
Backup is usually 5-6 minutes under load and 15-20 minutes idle. Both these numbers come down, depending how close you are the the UPS throughput.
asingh is offline
- by ax3
