I just installed a 2nd HD4890 on my system, so am running X-fire. Now something I did not foresee, my current UPS : APC 650VA only supports ~390W. At load I am almost pulling 550W+, and the APC 650VA is not supporting my system.
Any good UPS, which I should pick up, I guess one with 1100VA should be good, which can support a throughput of ~650W-670W...???
wat PSU u having, corsair or Tagan.. ?? if u hv any one of them also, both are ACTIVE PFC PSU's wich means they will REQUIRE (its mandatory, so plz do not skip this) a PURE SINE WAVE UPS and a minimum of 1100VA rating UPS,
so go for APC's SMART UPS range of UPS and u will be fine with the system setup..
join my orkut community to download latest movies, music & games here's the link to view it http://www.orkut.com/Community.aspx?cmm=38665088
