22-06-2009, 08:39 PM
EXPLORING!!!!!
LG LCD Query
Hi guys....if u remember i had zeroed in on the samsung 2233sw after a lot of help frm u guys....now 2 of my dealers in mumbai frm whom i regulary purchase stuff dnt hav it in stock n said mite take 3-4 days more 2 get....meanwhile i saw the lg w2224ws or 2224ws( dnt remember exactly)...now though the model was nt attractive, it had 16:10 aspect ratio which sounded gud 4 my graphic designing n 3d wrks...can u pls guide me on the drawbacks n advantages of 16:10 versus 16:9...ALso, kindly giv ur opinions on LG models available...max budget 10.5k...THANX
_____________________________________________
AMD Phenom II 920__GIGABYTE GA-MA78GM__1.75TB HDDs__6GB DDR2__CORSAIR VX550___ZOTAC GTS 450 Amp Ed!!___Samsung Syncmaster B2230__DELL INSP 15
22-06-2009, 09:15 PM
Tech addict
Re: LG LCD Query
If it is a 24" 16:10 model then most probably 1920x1200 native resolution that means if you are going to watch any video which is full HD (1920x1080) then you are going to have black strips horizontally of 1920x60 on upper and lower side of your panel. And that is its major drawback.
22-06-2009, 09:36 PM
EXPLORING!!!!!
Re: LG LCD Query
oh...but is that all?? is that the only Disadvntge??? i mean what wen it comes to gaming? does it affect gaming too? in what way??? and could u pls provide the costs of LG LCDs in my above mentioned budget...thanx...
22-06-2009, 10:20 PM
Tech addict
Re: LG LCD Query
yes, there is no drawback in gaming but you have to upgrade your GPU to have reasonable FPS in gaming if you wanna play games on its native resolution. L.G W2243T 22" @10.3K but my favorite is Samsung 2233sw @10.2K.
22-06-2009, 10:33 PM
EXPLORING!!!!!
Re: LG LCD Query
ok...mine is the same....but is there any noticeable diff btwn the 2 specs-wise???
23-06-2009, 07:31 AM
Tech addict
Re: LG LCD Query
Nothing special apart from looks and after sales service (very subjective place to place).
25-06-2009, 09:49 AM
Re: LG LCD Query
If you're interested in LG then please see W2243T its full HD panel with 16:9 ration. 30000:1 DCR and 2 MS RT. Priced @ Rs.10.2K. Its a decent buy. LG service is really good and you can rely on that.
Phenom II X4 940, Gigabyte MA790GP-UD4H, Corsair 6GB DDRII, AOC Fovi F22, Creative Gigaworks T3 Speakers, NZXT Phantom, Corsair GS600, 15 TB HDDs, Shure SRH440, Klipsch S4i, Ipod Touch 64gb
25-06-2009, 12:57 PM
Re: LG LCD Query
If you are planning to go for 24" i would suggest you go for Dell 2409WFP! Its e-ips panel monitor! I don't what is its price, please ask your dealer about it!
25-06-2009, 04:31 PM
Re: LG LCD Query
Sorry made a mistake in the model number. 2409WFP is VA display and its extremely costly! E-IPS panel monitor is 2209WA. You can go for this one!
