Old 21-06-2009, 07:09 PM   #1 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
Default is 60 C cpu temp. too hot?
i have an amd athlon 3500+ (clawhammer) .mobo- msi rs 482(ati x200).
the core temps seem to be around 60C. Isnt it too hot?
i measured the temp using speedfan & coreTemp.
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is online now
Old 22-06-2009, 10:29 PM   #2 (permalink)
Designer Here
techking_dinesh's Avatar
Default Re: is 60 C cpu temp. too hot?
Not at all hot
It`s Fine
Njoy !!
techking_dinesh is offline
Old 23-06-2009, 12:33 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
you better keep it below 50.
desiibond is offline
Old 23-06-2009, 12:35 AM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
60 is definitely hot for that processor.
Old 23-06-2009, 01:19 AM   #5 (permalink)
how can i do it.. could u please give suggestions/advice ?
Old 23-06-2009, 01:52 AM   #6 (permalink)
The High 5 Flyer
sam9s's Avatar
Idle yea may be..... 45-55 should be the range in summers......if on load 60 is absolutely acceptable...
sam9s is offline
Old 23-06-2009, 02:12 AM   #7 (permalink)
i am talking about idle temps.. it seems sometimes my pc is hanging when i run the browser with many tabs & music.. the temps reach 67C.. & higher
Old 23-06-2009, 02:21 AM   #8 (permalink)
Intel OCer
amitash's Avatar
Wow 60+ on idle is HOT....you need to remove your heatsink, clean all the dust, clean the IHS of the procy and the bottom of the HSF with some isopropyl alcohol or atleast paint thinner, then reseat with fresh thermal paste...AS5 is the best but for cheaper solutions you can get decent cooler master thermal paste quite cheap...that will prolly solve your issue.
My site: collegeclassroom.org
amitash is offline
Old 23-06-2009, 02:25 AM   #9 (permalink)
^^dude ... i have never done all this.. anywhere ... i can get exact instructions.. how to do this cleaning?
Old 23-06-2009, 03:46 AM   #10 (permalink)
damnbadman666
damngoodman999's Avatar
In summer u ll get like these !! just re apply the Good thermal paste ,
damngoodman999 is offline
Old 23-06-2009, 05:50 AM   #11 (permalink)
The High 5 Flyer
sam9s's Avatar
67 idle is not advisable, also reapplying the Thermal past is the last alternative I would recomend, there are lots you can try before, like make sure your stock fan is running at its max speed (check bios). the cabbie should be clean from dust and well ventilated with atleast 2 fans preferably 120mm. One for intake and one for exaust (u can have more if your cabbie allows). How the fans are placed is also imp. The exaust should be at a higher level. I am sure with all this you would easily get a drop of 4-5 degree C. If all this is not giving the result, go for reapplying the thermal past, or get a better CPU heatsink.
sam9s is offline
Old 23-06-2009, 07:01 AM   #12 (permalink)
Hot? Nah
It's nothing compared to what temperature i got once!
Once i made Tea on the top of my processor!
It was a 113 degrees at that time.
I made ice tea and temperature is in Farhenheit
The maximum temperature i have got is about 80 degrees celsius.
Aspire is offline
Old 23-06-2009, 07:25 AM   #13 (permalink)
The Sorcerer's Avatar
Change the thermalpaste. If its 60 degrees on idle or on load without any overclocks, it is high. Use isopropyl alcohol with above 90% alcohol content to clean the old thermal paste and get a decent enough thermal paste.
Hardware BBQ
The Sorcerer is online now
Old 23-06-2009, 07:50 AM   #14 (permalink)
Bond, Desi Bond!
desiibond's Avatar
1) add thermal paste to CPU
2) add additional fan at side or front.
3) if rear fan is not there, add one immediately
Old 23-06-2009, 08:27 AM   #15 (permalink)
Tech addict
surinder's Avatar
Yes boy for the first time its very tricky to remove a stock cooler of old Athlon 3500+ from MOBO its releasing leaver is very stiff.
BTW if wanna try to do this. First remove side pannel of PC's cabinet. Now use a wide tip screw driver to push the releasing leaver from C shaped formation side. keep that in mind the tip should be wide enough to stuck in that but should not touch the motherboard. Now push it gently downwards thenafter sideways heatsink will be unlocked.
Taking out processor is rather simple afair use its releasing leaver first sideways then upwards unmout the processor.
Rest of the prosses is well explained by other forum mambers.
surinder is offline
Old 23-06-2009, 10:20 PM   #16 (permalink)
Searching for Anti-Matter
Power_user_EX's Avatar
60 is a bit hot. Temps below 55~53 are normal.
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
Power_user_EX is offline
Old 23-06-2009, 10:27 PM   #17 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
That WAY too hot. I think you REALLY need to check the cooling in the cabinet. It should be below 55 degrees. Last resort is reapplying the thermal paste.
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
Liverpool_fan is offline
Old 26-06-2009, 01:42 AM   #18 (permalink)
Freshly Churned Chutny :)
Debu_013's Avatar
I had the same problem a few days back.
it was because of the faulty fan on the cooler it spun at only 1400RPM insted of 3500RPM now.
Check your CPU fan speed under load and check BIOS setting of the fan speed also.
+==CPU= AMD Athlon II X2 250 3.0 GHz
+==MB== AMD 690V (MSI K9AGM4)
+==RAM= Transcend 2GB DDR2 800MHz
+==Graphics_Card= XFX GeForce 8600GT 256MB GDDR3
Debu_013 is offline
Old 26-06-2009, 02:08 PM   #19 (permalink)
k... will do.
Old 02-07-2009, 04:40 PM   #20 (permalink)
It's no too hot.
yiouyio is offline
Old 02-07-2009, 06:49 PM   #21 (permalink)
Super Moderator
asingh's Avatar
What about the vCore voltage. My heating issue got resovled cause of that. There was too much juice going into the cores...!
Though do run some stability tests...preferrably RealTEMP using Prime95(two worker threads)..Run it 3-4 times. If you get a crash..raise the vCore a notch.
Is everything on stock...? Check the voltages..before you pull of the heat sink. Though how long since your heat sink assembly was cleaned out and reapplied..??
asingh is offline
- by ax3
