Old 15-06-2009, 11:06 AM   #1 (permalink)
static_x's Avatar
Default RAM Under-rated
Hi,
Assembled my new system with:
AMD Phenom II X4 940
Gigabyte GA MA790GP - UD4H
Corsair 800Mhz 2GBx2 RAM Modules
My system is showing only 2.75 gb of RAM. I understand that OS being 32bit the RAM showed is less than 4 GB. But my office PC (HP System - using E7400+4gb RAM) shows 3.31 GB of RAM. I cant understand why there is such difference of RAM Capacity? Does it depends on the Processor and MObO used?
Also, if i install 64bit XP then do I've to install all my softwares again i mean will the current softwares which run on this 32bit sys will work on the 64bit machine?
static_x is offline
Old 15-06-2009, 11:28 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: RAM Under-rated
dude. if you haven't installed any GPU, onboard GPU will take 512MB of RAM.
desiibond is offline
Old 15-06-2009, 05:04 PM   #3 (permalink)
I think there was a similar probs with ram in this forum...' it was the os I mean the win xp 32 bit that was causing it....?
Reinstall the winxp and then c it..'
Arnab boss is offline
Old 15-06-2009, 11:23 PM   #4 (permalink)
Crowman
Krow's Avatar
I have the same Board and Proc. RAM in XP 32 bit is 2.75 GB! Try GPU-Z and u'll c that u have 640MB VRAM. 512 MB is shared minus the GFX Card. If u have a GFX card installed, then its a prob. With integrated gfx, its not.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
- by ax3
