Old 14-06-2009, 11:28 PM   #1 (permalink)
webgenius's Avatar
Default Same internet connection for PC and laptop
Hi,
I'm using Dataone Home500 plan for my PC. How can I use my laptop to access internet on the same connection?
The modem I have is Huawei SmartAX MT882.
webgenius is offline
Old 15-06-2009, 05:03 PM   #2 (permalink)
Default Re: Same internet connection for PC and laptop
There's more than one way to do it. Your modem has one USB and one ethernet port, right?
Just connect the USB output to the desktop and the ethernet output to the laptop, or vice versa.
You can also use an inexpensive network switch or hub, connect the uplink port to the modem, and the other ports to your computers.
Or you can use a wireless router.
pimpom is offline
- by ax3
