Old 14-06-2009, 07:53 AM   #1 (permalink)
Unhappy PC restarts automatically after shutdown
Hi ALL,
Whenever I shutdown my windows os, the process goes well till the poweroff stage, but after a second or two it gets powered on automatically and starts to boot.
Right now I'm disconnecting power through the powerswitch behind the smps. Any clue whether its a fault in SMPS or motherboard.
I have a coolermaster extreme power 390w smps, Biostar TPD35D2 mobo. I verified the frontpanel connectors several times with the manual to ensure that the switches are connected to proper source. The system is stable always and no disruption in power even in case of fluctuations.
help me to shoot out this problem.Thanks
kkeng is offline
Old 14-06-2009, 09:04 AM   #2 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Default Re: PC restarts automatically after shutdown
Right click My Computer >> properties >> Advanced >>Startup & Recovery and in System failure box uncheck Automatically restart and press Ok...
Check this site too:
http://www.microsoft.com/windowsxp/u...l_02may13.mspx
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 14-06-2009, 11:43 AM   #3 (permalink)
Thanks but my problem is nowhere related to software, looks certainly something to deal with h/w. Regardless of the os I run the system goes powerred off completely but gets power then by some means. Updated Bios with the most recent firmware but no luck.
kkeng is offline
Old 14-06-2009, 12:23 PM   #4 (permalink)
RMN
my old system use to switch on auto due to a bad PSU
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
- by ax3
