Old 13-06-2009, 11:23 PM   #1 (permalink)
Exclamation PC powers ON without pressing the powerbutton
When i turn on the UPS the PC turns on by itself, without pressing the power button of the PC, I opened the cabin, disconnect the POW SW , power switch cable to mother board. Still, when the ups is on, the pc boots with out pusing the power button.
Ive no clue whats happning, defective mother board!!!?
TECHNOMANCER
vineeth_pulari is offline
Old 14-06-2009, 12:13 AM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Wink Re: PC powers ON without pressing the powerbutton
So, what is ur problem?
Why r u worried?
Even my pc has it. And I'm too happy to get it. Now I can continue D/L even if I'm not in home.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 14-06-2009, 12:33 AM   #3 (permalink)
Default Re: PC powers ON without pressing the powerbutton
change your smps (psu) with high watts psu
collermaster 500watts or crosair vx450
or atleast zebronic 500watts
raj_v1982 is offline
Old 14-06-2009, 02:13 AM   #4 (permalink)
Vineeth, your motherboard BIOS will have an option to change that. It will let you choose if you want to have the computer turn on automatically when it receives power. You can enable it or disable it. It is usually disabled by default. You might have enabled it without realising it.
The exact place in the BIOS menu for changing that setting is different for different motherboards. It may be under 'Advanced' or 'Power' or 'Power Management' or something similar.
The wording of the menu line will be something like "Restore on AC Power Loss'. If you tell us the model number of your motherboard, I'll try to find the manual online and give you more precise instructions.
pimpom is offline
Old 14-06-2009, 05:35 AM   #5 (permalink)
Freak Beta 1
Dark Core's Avatar
@vineeth_pulari
This s not coz of defective mobo, it's coz of a setting in BIOS - Search for Auto Power On, or similar terms in your BIOS (depends on d mobo model) and disable it.
Twitter : www.twitter.com/arunselvakumar :twisted:
Facebook : www.facebook.com/arunselvakumar :evil:
Dark Core is offline
Old 08-07-2009, 06:41 PM   #6 (permalink)
dIgItaL_BrAt's Avatar
offtopic: SKYNET???
dIgItaL_BrAt is offline
Old 09-07-2009, 12:08 AM   #7 (permalink)
icebags's Avatar
Originally Posted by dIgItaL_BrAt View Post
offtopic: SKYNET???
interesting point there. this might be it! begining of the end!
icebags is offline
Old 09-07-2009, 02:17 AM   #8 (permalink)
In search of light...
abhi.eternal's Avatar
i had the exact same issue a week back, only difference being i don't have a UPS. anyway, with my system i was not getting any display so i had to give it away for repairs. the repair guy told me that my TV card was using too much power... bull$hit... i tried with all the cards and connectors out and still the processor fan was starting the powered on the main switch. however, its fixed now and i m getting the display. one interesting thing is i had to set up the BIOS again as i had removed the CMOS battery. i think i selected "Restore on AC Power Loss'... because even now the system is starting but at least i m getting the display... so am not bothered much.. will check this when i get home...
http://abhijeetdeb.com
abhi.eternal is online now
- by ax3
