Old 11-06-2009, 09:37 PM   #1 (permalink)
harishgayatri's Avatar
Default Need to Buy a SATA I HDD
320GB 16MB buffer
Please tell me the SATA Drives which are SATA I and II complatible
harishgayatri is offline
Old 11-06-2009, 10:02 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: Need to Buy a SATA I HDD
I thnk all SATA II r SATA I compatible.....!!!
Well not sure....
Wait for othr members till dey reply
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 11-06-2009, 10:09 PM   #3 (permalink)
Tech addict
surinder's Avatar
Ya all SATA ll HDDs are SATA l compatible.
Get WD WD320AAKS 320 GB @2.2K.
surinder is offline
Old 11-06-2009, 10:19 PM   #4 (permalink)
Point Blanc
SATA 2 HDD can be put on SATA 1 port and viceversa, no issues in there.
acewin is offline
Old 12-06-2009, 08:23 AM   #5 (permalink)
paroh's Avatar
sata 1 is backward compatible with sata 1 port. So there will be no problem.
paroh is offline
Old 12-06-2009, 09:42 AM   #6 (permalink)
Exclamation Re: Need to Buy a SATA I HDD
Guys how good is Hitachi 320GB does it have a Jumper or something to make it SATA 1
Primeabgb is selling it at Rs 2150+(50) for me as delivery chrgs.
Does Hitachi also have 16MB buffer option
Old 12-06-2009, 02:00 PM   #7 (permalink)
Tech addict
surinder's Avatar
Go for WD WD320AAKS (blue power series 16MB buffer) 320 GB @2.2K eyes closed.
surinder is offline
Old 12-06-2009, 04:22 PM   #8 (permalink)
15.0 GHz
VarDOS's Avatar
their is nothing wid SATA 1 or 2, its only the increase of Bandwidth in Sata 2, than Sata 1.
You Can Go For Hitachi, it is also a good option, I Myself use it for 3 years now, no problem at all
VarDOS is offline
Old 13-06-2009, 07:40 AM   #9 (permalink)
Ok I will Stick to Hitachi.
Surinder, I have Western Digital 1TB External HDD Essential Edition and i guess it is a Green one.
Please confirm whether it is green or not
Thanks for your support guys
Old 13-06-2009, 07:48 AM   #10 (permalink)
My config is
Motherboard: Intel D865GBF
Processor: Intel Pentium 4 3.0Ghz Prescott HT enabled
RAM: 2x512MB DDR 400Mhz Dual Channel
Storage: 80GB SAMSUNG IDE based
Optical Drive: LITE-ON DVD SHD-16P1S
LITE-ON DVDRW LH-20A1P (Made to stock from MoserBaer)
Display: SONY BRAVIA T-Series KLV-19T400A (19 inch 16:10)
Graphics: ATI Radeon HD3650 AGP 8x 512MB DDR2
Sound: Onboard SoundMax 4XL
Old 13-06-2009, 08:09 AM   #11 (permalink)
Tech addict
surinder's Avatar
Give me the model number please required to determine whether it is green or not. But most probably it should be a green one.
surinder is offline
Old 13-06-2009, 08:48 AM   #12 (permalink)
This is the one
http://www.wdc.com/en/products/products.asp?driveid=353
Old 13-06-2009, 09:03 AM   #13 (permalink)
Tech addict
surinder's Avatar
Yes it is from green power series.
surinder is offline
- by ax3
