Old 09-06-2009, 06:43 PM   #1 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Default Need LCD monitor
Guys, i hav been using my samsung syncmaster 793 for 4 yrs.
I use system heavily for browsing,gaming movies n other s/w applications.etc.I am afraid of my eyes because i use it for long durations.Now i decided to buy an lcd monitor.
I need LCD for
to reduce my eye srain during long sessions.
optimal for gaming , movies
budget is 8000/rs
now i am looking for a 19" or 20" one.But 1 doubt does monitor size increase my eye strain? due to long sessions..?
(now i dont hav spects or ny visual prob but if i continue to use my crt it will happen soon)
i hav been using a decent distance from the monitor almost 1.5 meter with my eyes.
I prefer dell n samsung models
Ur suggestions plz....
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline
Old 09-06-2009, 06:47 PM   #2 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default Re: Need LCD monitor
U can go for Samsung 2033. And ofcourse u can keep a distance between LCD & yourself. I don't think there will be eye strain problem in LCD, if u keep a good distance.
Blogging at:
Technostarry
saqib_khan is offline
Old 09-06-2009, 10:37 PM   #3 (permalink)
Tech addict
surinder's Avatar
+1 for Samsung 2033 @7.5K
For eye care try to place the LCD opposite light source in the room. Place your monitor as such way that its top end remains 3" below your straight eye level to avoid glare and keep it at least two feet away from your eyes. keep contrast and brightness levels up to comfortable level use 60% brightness 40% contrast to lit up the screen. Like if brightness is at 50 then take contrast to 33.
surinder is offline
Old 10-06-2009, 10:01 AM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Get BenQ's G2220 21.5" FULL HD @ 9.2k
From 8k to 9.2k, it's worth every penny.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 10-06-2009, 10:03 PM   #5 (permalink)
Tech addict
surinder's Avatar
Then he have to upgrade his graphic card due to increased resolution plus PSU due to increased power consumption as well for sake of gaming as one of his consideration.
Plus increased strain on eyes as well.
surinder is offline
Old 10-06-2009, 10:20 PM   #6 (permalink)
Will you prefer a High Definition TV instead, in your budget ?
I am selling my Samsung High Definition TV which is working as my high definition PC monitor as well. It comes with HDMI and component inputs (other than S-Video, Composite and D-SUB inputs)
Resolution is 1440x900 (wide screen HD)
Supports 720p and 1080i and is HD ready.
Consumes just 45W of power.
I have posted the ad on this website but somehow it will take a little while before it actually gets visible (mods need to approve it). You can watch the pics here though :
http://www.erodov.com/forums/samsung...tor/20874.html
PM in case you are interested.
vasishta.sushant is offline
Old 16-06-2009, 09:21 PM   #7 (permalink)
mac555's Avatar
i also have a query related to lcd monitor.......can some one tell me 19'inch lcd monitor for gaming and programming??
mac555 is offline
Old 16-06-2009, 09:30 PM   #8 (permalink)
Tech addict
surinder's Avatar
Very same Samsung 2033 @7.5K.
surinder is offline
Old 17-06-2009, 12:25 AM   #9 (permalink)
I M A *STAR*
saqib_khan's Avatar
^^ Yes, +1
Blogging at:
Technostarry
- by ax3
