Old 08-06-2009, 10:24 PM   #1 (permalink)
15.0 GHz
VarDOS's Avatar
Default Wiered Problem
Hi Friends,
As I learned about assembling PC's, I unassembled my PC cuz it was rebooting frequently and i got 2 know the problem was b'cause their were blug of dirt found in my processor Heat-sink, and also my cooler fans, so the fans were having disturbance in spinning, i seperated each and every part of my CPU, cleaned it and re-assemble it again, PC started without any problem, but it is not showing Network Adapter in device manager, i.e Intel 10/100VE Network Connection if we refresh Device Manager then too its not workin, and same wid Sound PC is not showing any Sound Hardware installed, if i try to re-install the drivers, then 2 it is not workin. Pls help
VarDOS is offline
Old 08-06-2009, 11:54 PM   #2 (permalink)
Point Blanc
Default Re: Wiered Problem
re-install OS, I do not think ur onboard LAN would have gone cuckoo so quick. Seems u have done quiet a work now , do some more now. after fresh OS install run device manager checks to see if all the devices are showing properly or not.
acewin is offline
Old 09-06-2009, 08:22 AM   #3 (permalink)
Tech addict
surinder's Avatar
Plus motherboard's chipset drivers as well after OS.
surinder is offline
Old 05-07-2009, 02:50 PM   #4 (permalink)
15.0 GHz
VarDOS's Avatar
i didn't reinstalled my OS but partitioned with Windows 7, but still the problem is same it is not showing my Sound in Device Manager and Also The NetworkAdapters, if i try to re-install the drivers it says there are no devices connected to The PC.
pls help
VarDOS is offline
- by ax3
