Netgear Wireless WGT624 Router
Specifications
Interface Ethernet Port
Ports 1 x 10/100M WAN; 4 x 10/100M LAN
Data Rates Up to 108Mbps
Security Stateful Packet Inspection (SPI) Firewall, Internet Policy,Wi-Fi Protected Access 2 (WPA2), WEP, Wireless MAC Filtering
Standards IEEE 802.3/3u, IEEE 802.11b/g
Frequency Band 2.4GHz
Antenna 2 dBi External Antenna
Buttons Reset, SecureEasySetup
Power Input 12 VDC
Dimensions 1.1 x 6.9 x 4.7(inches)
Weight 0.32kg
Features
Features Internet sharing broadband router and 4 port switch
2x the speed and 4x times the coverage of a Wireless-G router?
Configurable for private networks and public hotspots
Double Firewall protection from external hackers attacks
Rs.2,840
Linksys WRT110N RangePlus Wireless Router
Specifications
Security Stateful Packet Inspection (SPI) Firewall, Internet Policy,128 bits, 256 bits
Wireless Security: Wi-FiProtected Access 2 (WPA2), WEP, Wireless MAC Filtering
Antenna 2 x 1.8 dBi Gain
Power Input 12V, 1A
Transmitted Power 16.5 dBm
LEDs Power, Ethernet (1-4), Internet, Wireless, Security
Weight 9.5 oz
Features
Features Internet-sharing Router and 4-port Switch,with a built in speed and range enhanced Wireless Access Point
MIMO smart antenna technology captures faint signals for extended range and reduced dead spots
Muchfaster than Wireless-G when connected to Wireless-N, but also works great with Wireless-G and -Bdevices
Wireless signals protected by wireless encryption, and your network protected from Internet attacksby a
powerful SPI firewall
Rs.4,239
Linksys WAG200G Wireless-G ADSL 2+ Router
Specifications Standards IEEE 802.11b, IEEE 802.11g, IEEE 802.3, IEEE 802.3u Buttons Reset Power Input ADSL, Ethernet (1-4) Transmitted Power 18dBm LEDs Power, Wireless, Ethernet (1-4), DSL, Internet Features Features ADSL2+ Modem, Internet-sharing Router, 4-Port Switch and Wireless-G Access Point in one box
High-speed ADSL+Modem gives you a fast, Always On connection to the Internet
Connect your home PCs and other wirelessdevices to the Gateway and the Internet using the built-in Wireless-G
Access Point, or connectdirectly with the 4-port Ethernet Switch
Advanced Firewall, Content Filtering and Security featuresprotect your PCs, your data, and your family
Rs.3,954
For more information check this site
http://www.techshop.in/store/main.php
