Old 05-06-2009, 06:49 PM   #1 (permalink)
IM ThE DEVIL
Davidboon's Avatar
Default Call of duty 4 freezes in game
I have a big problem with call of duty 4 multiplayer , i cant play more than 5 minutes in multiplayer as the game freezes and hangs so i have no option other than to restart the pc , but i can still hear the voices .
i figured that the problem is with my hardware
from the event logs i could find these errors.
Log Name:      System
Source:        atapi
Date:          05/06/2009 14:14:15
Event ID:      11
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      Lovejeet-PC
Description:
The driver detected a controller error on \Device\Ide\IdePort2.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="atapi" />
    <EventID Qualifiers="49156">11</EventID>
    <Level>2</Level>
    <Task>0</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2009-06-05T08:44:15.770Z" />
    <EventRecordID>9579</EventRecordID>
    <Channel>System</Channel>
    <Computer>Lovejeet-PC</Computer>
    <Security />
  </System>
  <EventData>
    <Data>\Device\Ide\IdePort2</Data>
    <Binary>0000100001000000000000000B0004C004000000850100C00000000000000000000000000000000001000000000000000000000005100000</Binary>
  </EventData>
</Event>
Here is my pc configuration :
Cpu : core 2 duo E4500
Motherboard : lenovo made
Graphics Card : Palit 9800GT 1GB
HDD : Hitachi deskstar 250 GB
can somebody point out the problem .
AMD Phenom II X6 1055T||MSI 890FXA-GD70||CORSAIR 4GB DDR3||2 * SEAGATE 500GB + WD 500GB ||ASUS EA5870 1GB||RAZER ARCTOSA||RAZER DEATHADDER||NZXT M59||BENQ G2220HD||CORSAIR TX650W||Canon 550D
Davidboon is offline
Old 06-06-2009, 01:29 PM   #2 (permalink)
Default Re: Call of duty 4 freezes in game
Check ur graphics driver updates and ur mobo update...'
Arnab boss is offline
Old 06-06-2009, 01:41 PM   #3 (permalink)
15.0 GHz
VarDOS's Avatar
as per the log ERROR is on IDE port, can u tell is u r HDD a SATA or IDE
VarDOS is offline
Old 06-06-2009, 02:38 PM   #4 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
It seems error is from DVD Drive. Do update all drivers & run game without DVD drive.
keith_j_snyder2 is offline
Old 06-06-2009, 04:17 PM   #5 (permalink)
IM ThE DEVIL
Davidboon's Avatar
@Varad i have a SATA HDD
and i have already updated my graphics driver to the latest version .
Old 08-06-2009, 01:49 AM   #6 (permalink)
If the prob is with this game then I think reinstall the game as some files may b corrupted...'
Old 08-06-2009, 01:15 PM   #7 (permalink)
IM ThE DEVIL
Davidboon's Avatar
finally the game is working fine , i just replaced the iw3mp.exe files from the dvd and now i can play continiously for more than 2 hours !
- by ax3
