Old 05-06-2009, 05:27 PM   #1 (permalink)
bajaj151's Avatar
Default Help : UMAX TV Tuner Purchase or Not ?
Yesterday, I went to computer shop and saw a TV Tuner Card
Name: Umax T-Vision UTV -8300i (INTERNAL TV TUNER CARD)
Specifications :
-Resolution: PAL-720*576, NTSC-720*480
-Infrared Remoter Control to Watch/Record TV
-Picture in Picture(PIP)
-Schedule Recordings & Timeshift Functions
- Support Composite Input
-Full Channel Scan & Auto Scan
-Encode MPEG1 MPEG2 files
-Support Video Play, image browse function
-Support still image snapshots and save to bmp,jpg files in pc
-Compatible with XP/Vista
Other Inform:
Uses Philips 7130 Chipset
I have BenQ E2200HD 22" LCD Monitor.
Will it work fine on my LCD ?????
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is offline
Old 05-06-2009, 06:10 PM   #2 (permalink)
damnbadman666
damngoodman999's Avatar
Default Re: Help : Purchase or Not ?
E2200 is HD monitor u will get horrible resolution from that TV tuner pinnacle just introduced the HD tv tuner card but its for 18.5" LCD were it not supports the 1920 X 1080 ,, its supports the 1366 X 768
damngoodman999 is offline
Old 06-06-2009, 12:46 PM   #3 (permalink)
bajaj151's Avatar
I want to buy it today...so please reply ?
bajaj151 is offline
Old 06-06-2009, 07:49 PM   #4 (permalink)
Point Blanc
did u already buy one, what is your budget.
You have quiet a few TV tuner cards which can play HD, but it costs more.
But anyhow the display will depend upon the transmission, if the digital or analog transmission is HD then only u will get high res. generally the transmission is quiet low here in India
acewin is offline
Old 09-06-2009, 11:08 AM   #5 (permalink)
Tech addict
surinder's Avatar
I haven't seen anybody enjoying true HD (1920x1080) transmission here in India. So don't worry about that at this particular time.
surinder is offline
Old 10-06-2009, 05:23 PM   #6 (permalink)
bajaj151's Avatar
Budget: 1000-1200
I want to connect Airtel STB
bajaj151 is offline
- by ax3
