Old 04-06-2009, 07:02 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Question creative sound blaster x-fi surround 5.1 USB card.
hi,
I need to buy the creative sound blaster x-fi surround 5.1 USB card for my laptop to get true 5.1 surround sound.
Anyone know what is the cost of the card & from where i can buy it.
I also got many negative feedbacks that it has driver problems in windows vista.
Can anyone able to solve this problem?
dishwara is offline
Old 04-06-2009, 08:50 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: creative sound blaster x-fi surround 5.1 USB card.
If you are referring to this one, its should cost around 4k I think:
http://us.creative.com/products/prod...ct=17751&nav=2
You can find the driver here:
http://support.creative.com/Downloads/welcome.aspx
I saw few threads about the driver issue but they were dated around May 2008.
desiibond is offline
Old 04-06-2009, 09:10 AM   #3 (permalink)
Thanks
Do u know any other USB creative cards which gives 5.1 output?
dishwara is offline
Old 04-06-2009, 09:24 AM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Does your laptop have PCMCIA Express slot?
Old 04-06-2009, 09:26 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
http://us.creative.com/products/prod...ct=10702&nav=1
Old 04-06-2009, 10:12 AM   #6 (permalink)
no pcmcia. only express card slot
dishwara is offline
Old 04-06-2009, 10:14 AM   #7 (permalink)
static_x's Avatar
ASUS has launched a new portable USB based Audio Station
The details can be found here http://in.asus.com/products.aspx?l1=...13&modelmenu=1
Priced @ 3.5K
static_x is offline
Old 04-06-2009, 10:23 AM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
how about somethinglike this:
http://us.creative.com/products/prod...6&product=9468
Found this in Golcha (bangalore) recently.
You may have to but external amp or decoder, use your audio out of laptop in passthrough mode to external amp.
Old 04-06-2009, 10:30 AM   #9 (permalink)
static_x's Avatar
hey that's a nice thing...whats the cost??
static_x is offline
Old 04-06-2009, 10:42 AM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
should be around 6k I guess
Old 04-06-2009, 11:02 AM   #11 (permalink)
Point Blanc
LOL, desi is enjoying his time
acewin is offline
Old 04-06-2009, 06:45 PM   #12 (permalink)
The creative decoder converts a stereo in to 5-7.1 output.
so, it means virtual surround sound, not true surround.
I have only 2 options to get true 5.1 sound from laptop.
1st is usb sound card- least expensive.
2nd is creative ExpressCard Sound Blaster X-Fi Xtreme Audio Notebook & Breakout box.
http://us.creative.com/products/prod...&product=16642
http://us.creative.com/products/prod...ct=16741&nav=3
But the cost of the both express card & breakout box is unknown.
mailed creative@cyberstarindia.com. but no reply so far.
dishwara is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/117753-creative-sound-blaster-x-fi-surround-5-1-usb-card.html
Thread ???? : Creative X-Fi Go! (USB sound card) | ??????? | Vmodtech.com : Webboard |??????,???-???,???????,computer,hardware,overclock | BoardReader This thread Refback 15-07-2010 09:41 AM
- by ax3
