My 1 year old, GeForce 8600GT 256MB DDR3 has ideal temperature of 59 to 60 degrees. Is it normal?
Under load, though the temperature varies very little it to about 75 degree max.
I dunno if Riva Tuner Fan Fix works on an 8600GT. Nevertheless, you can try to increase fan speed, something like 80% +
And yes, do the cleaning process and make sure ur cabby is ventilated and some big wires aren't coming in the way or so. Otherwise, it's perfectly normal.
What do I use to set fan speed to 80%+.
My 8600GT is from XFX and i cannot find any tool bundled with it, to tweak fan speed.
Would it be wise to install the MSI version of of nvidia graphics driver, because i have a MSI MB , and then the graphics card controls would be activated on MSI Dual Core Center.
there is nothin like that. All u have to do is head to guru3d.com and download latest rivatuner, and increase the fan speed, and save for every bootups.
and max of 65c for an 8600GT is more than ok. u shudnt start worrying until it idles at 70+ and max goes beyond 80c.
