Old 02-06-2009, 08:20 PM   #1 (permalink)
Question Which cabinet? cooler master 690 or cooler master Gladiator 600
Hi
I am building gaming system with HD4850, E8400, intel mother board, cooler master 600watts smps, 500gb hard drive, 2x2 gb ram (800mgz ddr2).
I have choice between following 2 cabinets, looks similar to me, please help me decide which one i should go asap.
CM 690 - Rs.5000
http://www.coolermaster.com/products...ate=17&id=2908
Gladiator 600 (RC-600) - Rs.4500
http://www.coolermaster.com/products...ate=17&id=6564
i have to decide by tomorrow. thanks.
btw, these prices are in mumbai.
here is the link to compare both
MaxBombay is offline
Old 02-06-2009, 10:23 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Which cabinet? cooler master 690 or cooler master Gladiator 600
My pick would be CM690
it's SLI certified cabinet with 3 more fan slots when compared to Gladiator 600
desiibond is offline
Old 03-06-2009, 09:14 PM   #3 (permalink)
Super Moderator
asingh's Avatar
same..am using the cabinet..love it...! Of course has more fan slots..too..!
asingh is offline
Old 03-06-2009, 10:05 PM   #4 (permalink)
15.0 GHz
VarDOS's Avatar
i would too go for CM690
VarDOS is offline
Old 03-06-2009, 10:30 PM   #5 (permalink)
guys.. how is the noise level of the same..
i always wanted to have a noise proof cabinet...
Is CM 340/341... good as well for that? Coz i understand that CM 690 is expensive and has the buttons and USB ports on top. But i am one of those ppl who use my cpu also as a mini table.
Always envy the dell/HP desktops which remain silent.
PROC: AMD X2 7750 BE, MoBo: Gigabyte M57SLI-S4 , Ram: 2*1GB 800 MHZ PC 6400,Cooler Master 500W SMPS, HD 1TB WD, 500 GB Seagate,2* 250GB, 160 GB,19" TFT,Logitech MX3200.
popularbhaskar is offline
Old 03-06-2009, 11:33 PM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Don't install any fans, use onboard graphics and the cabinet will be silent
Old 03-06-2009, 11:53 PM   #7 (permalink)
but my hard disks are like a gang of dogs.. they all keep barking.
Btw.. Did you receive my Sys config details on PM?
Old 03-06-2009, 11:53 PM   #8 (permalink)
Also.. my fan on cpu is sounding like a propellar. Is that normal for a AMD 7750 BE cpu?
Old 04-06-2009, 02:48 AM   #9 (permalink)
i am going for gladitor because cm690 is too big for my computer table, it won't fit in
Old 04-06-2009, 09:07 AM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@popularbhaskar, looks like you might need a thermal paste. Monitor your CPU temperatures using everest or speedfan. Should be below 45 when idle and less than 60 when on load
Old 04-06-2009, 12:25 PM   #11 (permalink)
Super Moderator
asingh's Avatar
Please take of the heat sink assembly and give a good clean up to the metal plates, and the fan. Believe me..even my old system..used to sound loud..once I cleaned the heat sink assembly it was really quite...
The way I cleaned it...was took a small brush..and rubbed it around..the metal..and fan fins. Also blew into the assembly really hard..couple of times. Do it outside your house..it raises a lot of dust.........!
Make sure you re-apply thermal paste, when you reseat the heat sink.
asingh is offline
Old 05-06-2009, 04:58 AM   #12 (permalink)
@Asigh
the problem in my case is the processor is a week old and i noticed the painful noise the moment i put the new proc and fan on.. i verified if the seating is good and it is.
Old 05-06-2009, 08:31 AM   #13 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
CM690 looks better to me (bcoz i have cm334 ),
CM 690 has 1blue front fan, 1 rear fan, optional top fan, 1 side fan, 1 optional so if you put those.. it bound to be loudy...\ it cant be silent.. consider this.. even if with standard 4 fans you have 6fans runing. it will be loudly. ( 4 cabinet + 1cpu fan + 1 smps = 6fans)
My CM 334.. and it looks identical, just a bit smaller. its awesome looking cabinet. even better than it appear on website. I have just one 120mm fan installed so its very very silent. I was thinking about putting one more but the silence is stopping me.
rollcage is offline
Old 05-06-2009, 07:18 PM   #14 (permalink)
Super Moderator
asingh's Avatar
I have all the fans loaded on my CM690. (1xDrive bays, 1xleft panel,1xbottom chassis, 1xback chassis, 2xtop chassis)...honestly..it is not that loud...+ I also have one PSU+one CPU+one GPU..total = 9 fans...!
The whole thing..makes a HMMMMMMMMM..sound...so it is not absolutely silent (I can tell something is on)..but it is quite enough to sleep and have it running in the background...!
asingh is offline
Old 05-06-2009, 11:11 PM   #15 (permalink)
rollcage's Avatar
^ no fan on Harddisk ? ..
damm .. man .. so many fans.. I envy you..
acha.. Just one thought.. which fans blow in and which one blows out?
rollcage is offline
Old 05-06-2009, 11:29 PM   #16 (permalink)
Super Moderator
asingh's Avatar
Hey..I was wrong...and your post corrected it...there is no fan on the drive bays..it is located in front of the hard disks...!!!
Intake Fans:
Hard Disk - Front Panel x 1
Bottom Chassis x 1
Left side Panel x 1
Exhaust Fans:
Back Panel x 1
Top Panel x 2
Heat Dissapating:
CPU x 1
PSU x 1
GPU x 1
Total: 9
asingh is offline
- by ax3
