Old 01-06-2009, 03:54 PM   #1 (permalink)
Section Moderator
gopi_vbboy's Avatar
Default Connecting two pcs through USB-LAN cabl through Router
Hi all,
actually i hav two desktop PCS....both having XP OS,Ethernet socket ,USB sockets
cables-Two Normal Ethernet CAT5(white one),USB cable that came with huwaei modem.I DON HAV CROSS OVER(YELLOW) CABLE.
modem: Huwaei MT882 router(BSNL one--USB n LAN with ADSL sockets behind it)
i want to connect the two pcs using router...one pc connected through USB to router n other through Ethernet
after connecting i get USB-LAN networks shown active on both pc's but ...ping test fails...connectivity is failing...
set both workgrp name same,even enabled file sharing,,..nothing works
any mistake i hav done...i set same gate way 192.168.1.1 for both n/ws
pcs i/p's
192.168.1.10
192.1681.11
any mistake or i did anythng wrong?pls help
gopi_vbboy is online now
Old 01-06-2009, 04:14 PM   #2 (permalink)
Section Moderator
gopi_vbboy's Avatar
Default Re: Connecting two pcs through USB-LAN cabl through Router
bump!atleast anyone tell is this connection possible?
- by ax3
