Old 31-05-2009, 08:23 PM   #1 (permalink)
Exclamation Help....Gaming PC....50K
Hello guys.....
I really need your opinion about my configuration. I am going to assemble my new PC in the coming 5 days. My budget is about 50k. Following is the confiig:
AMD Phenom 2 940 BE – (10.8k)
Motherboard – Need suggestions, ASUS/Gigabyte/any other - (5k) ???
Corsair 3GB DDR2-800 – (2.3k)
Palit GTX 260 Sonic 216 896 MB – (11k)
WD 500GB 32MB HDD – (3.1k)
Sony DVD/RW 22X – (1.3k)
NZXT Guardian 921 Cabinet – (4.5k)
Antec EA650 or Corsair 550VX – (4.8K / 5.5k) ???
Samsung 2233SW 21.5” LCD – (10.1k)
Total – 53k
Please feel free to suggeest any other configs and do suggest a good mobo for 5k which is good for gaming and moderate overclocking. The sole purpose of the system is Gaming....
I have quoted prices from Lynx-India.com.....Is this site safe for purchasing and are the prices correct?
In my city the dealers quote more price for the same components.
I also have the option of ordering these from Tirupati Enterprise, whose owner is my friend’s bro....
Waiting for ur suggestions......
nsgage is offline
Old 31-05-2009, 08:52 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Help....Gaming PC....50K
Gigabyte MA78GM-US2H mobo for 5.1k or Jetway HA-07 Ultra for 6k
for PSU, I would pick Corsair.
For RAM get 2x2GB Corsair XMS2 for 3k. And install 64bit OS.
For Cabinet, I would pick Cooler Master CM 690 over NZXT Guardian 921 as it has room for 8 fans and that helps cooling a lot and both are at same price.
desiibond is offline
Old 31-05-2009, 08:53 PM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
moreover, apart from LCD, I don't find anything worth in NZXT Guardian 921 for 4k+ bucks.
Old 31-05-2009, 09:00 PM   #4 (permalink)
Crowman
Krow's Avatar
VX550W any day(acc to me)! - 5.8k
Get LG 22x SATA instead - 1.1k
If u like it, u cn get the CM-690 - 4.5k
For a mobo u cn hv a look @ GA-MA-790GP-UD4H @ ~9k or any Gigabyte UD series board with the 780G chipset if u r really budget bound.
Spending less on mobo isnt so wise as if u r gonna be heavily gaming, u must have a board with a great build quality.
Corsair 3GB DDR2-800 – (2.3k)??? 3x1GB or 1x3GB?
Get 2x2GB for dual channel bandwidth utilisation, although ur choice is also good.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 31-05-2009, 09:00 PM   #5 (permalink)
dOm1naTOr's Avatar
Antec EA 650 SLI is a real wise choice. Its seasonic OEM and has extreme vfm @ 4.8k
and everythin else looks fine. get the mobo suggested by desiibond
Samsung 22X sata burner might be better than Sony.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 31-05-2009, 09:12 PM   #6 (permalink)
Intially i had also chosen cm690, but it has too many nets and meshes through which dust can settle inside the cabinet. I read good review on the net about guardian 921.....but do u have any other cabinets u can suggest at the same price...wat about thermaltake m9d or nzxt lexa?
its 1x2gb and 1x1gb
nsgage is offline
Old 31-05-2009, 09:17 PM   #7 (permalink)
Is this gigabyte mobo better than asus m3a78-em or m3n78-em. I also saw on gigabyte's site that this mobo is am3 ready.....will it work all right if i upgrade about 2 years from now?
nsgage is offline
Old 31-05-2009, 09:30 PM   #8 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
P2 940 B.E. @ 10.5k
Biostar TA790GXB A3+ @ 5.8k
2*2GB Kingston DDR2 800MHz @ 2k
NZXT Guardian @ 4.6k
Corsair VX450W @ 3.9k
Seagate 7200.12(faster read/write speed) 500GB @ 3.1k
22x DVD Writer @ 1.2k
Samsung2233SW @ 10k
PowerColour HD4890 1GB GDDR5 @ 15k
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 31-05-2009, 09:37 PM   #9 (permalink)
damnbadman666
damngoodman999's Avatar
ASUS M4A78-E Motherboard with 790GX/SB750 chipset ,, it comes with Crossfire support
Costs u 7K
damngoodman999 is offline
Old 31-05-2009, 09:40 PM   #10 (permalink)
Originally Posted by comp@ddict View Post
P2 940 B.E. @ 10.5k
Samsung2233SW @ 10k
Thnx for ur suggestion!!
But I read somewhere that biostar mobos are unstable with latest phenoms...is it true?
Will the Corsair 450vx suffice the gtx260 or 4890 u've mentioned?
Also I dont think its a good idea to spend 5k extra for about 5-8 fps max gain, since palit's 260 is already overclocked.....
nsgage is offline
Old 31-05-2009, 09:47 PM   #11 (permalink)
Crowman
Krow's Avatar
Don't worry too much abt the dust settling as no matter what cabby u get, the dust is gonna enter and settle in! Hence don't let that affect ur choice as if u get urself a paintbrush + hand blower + dry cloth and clean ur case once every month, any cabinet will remain dust-free and cool. Remember to clean ur case regularly! I would still vouch for the CM-690 w/the transparent panel.
Krow is offline
Old 31-05-2009, 11:35 PM   #12 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
@ nsgage, the board I've mentioned won't give you a single problem. It's a new one with CFx support too.
Further, I suggest you can also buy a X3 720 B.E. instead!
About me:
Old 01-06-2009, 12:24 AM   #13 (permalink)
damnbadman666
Is PALIT GTX 260 SP216 SONIC edition is faster than PALIT HD 4850 1GB SONIC edition ???
Old 01-06-2009, 03:17 AM   #14 (permalink)
dOm1naTOr's Avatar
ofcourse GTX 260 is much faster. GTX 260 216 competes with 4870 1GB.
And EA 650 has same OEM as Corsair VX. Both are seasonic. So EA 650 is as stable as 80+ efficient. It can be overloaded to 120%[like VX], upto 780W or even more.
CM 690 is good, but its kinda common now. The Guradian looms cool and reviews are good. Go for it.
And get 2x2Gb memory for problem free dual channel support. Some chipset suporrt variable size modules to run in dual channel, but some limitations. Better get two 2G identical 800Mhz chips.
G3: XPS M1530 |
FZ 16.
Old 01-06-2009, 06:48 PM   #15 (permalink)
laborare est orare
Cilus's Avatar
Originally Posted by dOm1naTOr View Post
ofcourse GTX 260 is much faster. GTX 260 216 competes with 4870 1GB..
One little correction. GTX 260 Core 216 are better than 4850 cards. They compete with the 4870 1GB version and is slightly better performer in normal condition (without tweaking). U can get the reviews from Guru3d.com. At 11k, they r really a very good buy.
Cilus is online now
Old 01-06-2009, 07:30 PM   #16 (permalink)
dOm1naTOr's Avatar
and whats the correction uve made?
G3: XPS M1530 |
FZ 16.
Old 01-06-2009, 07:47 PM   #17 (permalink)
j1n M@tt's Avatar
lol...nice correction
but domi, EW 650SLi costs 4.8k, where as VX450 is only 3.9k-4k.
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 01-06-2009, 08:03 PM   #18 (permalink)
dOm1naTOr's Avatar
but VX 450 is 450 and EA 650 is 650.
EA 650 is even better than VX 550[5.8k] and almost close to TX 650[7k]. and costs meagre 4.8k, though less warranty.
G3: XPS M1530 |
FZ 16.
Old 01-06-2009, 08:14 PM   #19 (permalink)
j1n M@tt's Avatar
I seriously doubt dat it matches to a TX650 dude...and EA 650SLi is best for SLi setup, dats y everyone prefers GP-AL650AA over EA 650SLi for normal setup.
j1n M@tt is offline
Old 01-06-2009, 10:25 PM   #20 (permalink)
dOm1naTOr's Avatar
Wat more could u ask for, from an 84% efficient PSU[at specified max looad] wich overloads more than 120% stable and runs oober cool ?
Feature, warranty, looks dun come close to TX, but in shear power and stability, it do match close.
G3: XPS M1530 |
FZ 16.
Old 02-06-2009, 10:42 AM   #21 (permalink)
I'm still in doubt over the mobo....
Which one should I buy:
1. ASUS M3A78-EM (<5K)
2. ASUS M3N78-EM (<5K)
3. ASUS M4N78 PRO (6.5K, ATX, AM3 ready, looks good)
4. Gigabyte GA-MA78GMUS2H (<5k)
Please suggest the best value for money motherboard which is fast for gaming and can overclock in future....
nsgage is offline
Old 02-06-2009, 11:00 AM   #22 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Pick among 3 and 4. I would pick no.4, thanks to it's better PCB (2oz copper sandwiched).
Also check Jetway HA-07 Ultra.
Old 02-06-2009, 11:01 AM   #23 (permalink)
Tech addict
surinder's Avatar
But why you want compare EA 650w with TX 650w there is huge price difference in them and dOm1naTOr only typed "almost close to" (not head to head) and yes Antec EA 650w holds the best VFM tag in its price/performance range according to me.
surinder is offline
- by ax3
