Originally Posted by ashwin.isaac
Hi all
Today i got a new samsung 2033SW monitor and pixelview tv tuner card play tv box 6.. But strangely it doesn seem to work. I guess d resolutions doesn match. D tuner has resolutions of 800*600 1024*768 1280*1024 1280*768 1440*900 1400*1050 and 1680*1050.. I tried all d modes but d screen jus comes on for a second and vanishes.  can anyone pls find a solution to this..
Do your monitor supports any above resolutions ? Consult the manual.
Say your tuner & monitor both supports 1280*1024.
. Set the tuner resolution mode to 1280*1024. Now the monitor should automatically pick the resolution of the tuner.
If it's not picking that up then the refresh rate the the tuner is passing to the monitor is much high or low. Check to see if you tune the refresh setting of the tv tuerr.
Did you checked the monitor with pc ?
check the tv tuner with other monitor & see if it works ?
