plz help me friends.............
my brother executed a command in command prompt by mistake and this created a file called bootex(a notepad file).
Now i can't delete any file and add any file to my pendrive.
It shows the the drive is write protected.
i think the command was chkdsk and it was stopped abruptly
the make of my pendrive is Transcand.-JF V30
^ Click on Autofix, click on Open File for analysis and then from the select the file, rightclick on it and select Delete. Otherwise try 8-X Kill.
Try Malwarebytes' Antimalware and Trojan Remover too.....
hello dic_junkie
i don't think it is trojan or malware
that file contains the following data
Checking file system on H:
The type of the file system is FAT.
One of your disks needs to be checked for consistency. You
may cancel the disk check, but it is strongly recommended
that you continue.
Windows will now check the disk.
Volume Serial Number is 7375-AB5B
Windows has checked the file system and found no problems.
2054881280 bytes total disk space.
786432 bytes in 2 hidden files.
589824 bytes in 18 folders.
1665761280 bytes in 1123 files.
387743744 bytes available on disk.
32768 bytes in each allocation unit.
62710 total allocation units on disk.
11833 allocation units available on disk.
From
✖яãђÙll™ ∂є ℓιттℓє ρяιηçє✖
^ If that file is causing problems, then I think you should delete it. It may not be a trojan or malware but it has made your drive write-protected. Delete it.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Also check if there is a small switch in the pen-drive. In many pen-drives, it is used to make the drive write-protected. Therefore if you find one, fix that.
i cannot delete even that file.It shows the pendrive is write protected.
no der is no switch.the file itself is causing the trouble.
From
bootex.log is created when your disk is scanned at boot time. (Remember "A disk scan is scheduled for checking the consistency of data" prompt that comes up during boot time which you can cancel by pressing a key.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
@ rahul_kmr007 - if you are using linux try formating it from there Or just delete the file from linux. If you don't have linux installed use any live distro.
