Old 30-05-2009, 01:10 AM   #1 (permalink)
Default New pc.
kindly advise on a pc in the range of 40k max 45k...i would have preferred Intel much more but have been going through all the posts and all you guys have been recomending AMD..so i am willing to try it but am bit weary abt the stability of it ...as i don't need to overclock just need a stable system for little gaming and movies...and request you to suggest a dealer in delhi whom we can rely on as dealer near my home is virtually selling a config for dbl the price i found on deltapage...
shikhar_kapoor143 is offline
Old 30-05-2009, 08:30 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: New pc.
AMD Phenom II X3 720 BE Processor: 7.5k
Gigabyte MA78GM-US2H or MA78GM-SH2P Motherboard: 5k
Corsair TWIN2X2048-6400C4 800 MHz RAM: 3k
Corsair VX450W PSU: 4.2k
Seagate 500GB sata2 HDD: 3k
CoolerMaster Elite 330 Cabinet: 2k
Logitech k/b and mouse: 2k (laser mouse)
sony/samsung dvd burner: 1.1k
Samsung 2233SW: 10.5k
Sapphire HD4770: 7k (enough for little bit of gaming)
desiibond is offline
Old 30-05-2009, 08:50 AM   #3 (permalink)
Default Re: New pc.
Ya dude Amd rocks...'
Now as u mentioned that u just want a sys 2 run stable and little gaming and movies here it goes...'
Proccy - Amd phenom 2 940 @ 10.8k
Mobo - biostar 790 128m @ 5.2k.
Hdd - seagate 500 gb @ 2.8k
Ram -kingston 2 gb 800mhz @ 1.4k
Gpu - xfx 9600 gt @ 5.5k.or hd 4770 @ 7k
Smps - Corsair vx 450@4k or cooler master 600 w @ 3.8k.
Moniter - samsung 2233 lcd @ 10.4k
Dvd rw - lg optical drive @ 1.1k
Keyboard &mouse -any bundled@.6k
Speakers - altec lancing 2.1 ch @ 2k, 5.1 ch @ 4k...'
Cabinet - zebronics antibiotic @ 2k or best go 4 cm 690@4.5k...'
this config will serve as u require and u can play games @ 1650* 1050 resolution with 9600 gt as my friend has this config and playing gta4 in that resolution...'
if u want a better mobo then opt 4 gigabyte ga ma790gx -ud4h @8.5k...'
Or else stick 2 biostar...'
4 case imo go 4 cm 690 as it has a good cooling options and u don't need 2 worry 4 future upgrades...'
Arnab boss is offline
Old 30-05-2009, 08:57 AM   #4 (permalink)
Default Re: New pc.
Ram -ocz 2 gb 800mhz @ 1.5k
Old 05-06-2009, 07:20 AM   #5 (permalink)
Default Re: New pc.
I have a small query as you have advised to the graphic card Sapphire HD4770, if I go for 4850 series would i have to make any changes on the motherboard.. and I have seen that Sapphire HD4770 is ddr5 and the cards that i have seen in 4850 are mostly ddr3. what difference does it make?
Old 05-06-2009, 07:53 AM   #6 (permalink)
Tech addict
surinder's Avatar
Default Re: New pc.
No you don't have to make any change with suggested MOBO. Yes very true but still 4850 will give you 10% to 15% performance gain over 4770 here are the differences
A typical 4850 GPU
Memory type: GDDR3
Memory Interface:256-bit
Stream Processors:800
Core Clock:625 MHz
Memory Clock:1986 MHz
Memory Bandwidth:147.0GB/sec (final outcome)
A typical 4770 GPU
Memory Type: GDDR5
Memory Interface:128-bit
Stream Processors:640
Core Clock:750 MHz
Memory Clock:3.20 GHz
Memory Bandwidth: 51.2GB/sec (final outcome)
surinder is offline
Old 05-06-2009, 08:55 AM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: New pc.
btw, Palit/Gainward has released GDDR5 version of HD4850. Try to get that.
Old 17-06-2009, 01:42 AM   #8 (permalink)
Default Re: New pc.
thnx for ur suggestions guys...but unfortunately haven't been able to purchase the system due to my job...well most probably i will be going with Desiibond's suggestion with 4850 insted of 4770...but have some queries if you may help with them:
1) If i go with a 790GX based motherboard..thinkin abt Gigabyte GA-MA790GP-UD4H any other suggestions apart from that.
2) And if i increase my budget a little so i can get a DDR3 compatible system so atleast i have a future proof system..
3) wht difference is there between a normal RAM and the one suggested for Corsair...
4) i had read somewhere that AMD may slash the rate of their 4XXX series in a week or so...so should i wait for that?
Old 17-06-2009, 02:12 AM   #9 (permalink)
damnbadman666
damngoodman999's Avatar
Default Re: New pc.
Welcome shikhar_kapoor143
I too use the same Mobo Gigabyte GA-MA790GP-UD4H . this mobo well works with pHenom 2 940
DDR3 its ok , but the mobo prices will be higher & u wont see much difference unless going in to corei7
Actually HD 4770 is good but availability is less & also gaming is little bit low resolution
u can choose either GTX260 or GTX 275 , both can take in to more gaming experience
damngoodman999 is offline
Old 17-06-2009, 07:46 AM   #10 (permalink)
Tech addict
surinder's Avatar
Default Re: New pc.
first and second of your quires are well answered by damngoodman999 for third and and forth here we go :-
(3)It gives you very low latency time of 4-4-4-12, somewhat overclockable, quality components used.
(4) yes very true and if you can wait to workout in Indian market (should take 15 days at most) then it worth waiting for better prices offered.
surinder is offline
Old 17-06-2009, 08:11 AM   #11 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: New pc.
@damngoodman, the difference between a ddr3 mobo and ddr2 mobo is 2k and difference in ram's price is 300 bucks. I see no reason not to go for ddr3 as an am3+ddr3 setup is much better for upgrade.
Old 18-06-2009, 04:36 AM   #12 (permalink)
Default Re: New pc.
desiibond any good mobo you can suggest? i am mostly looking for gigabyte anyothr option available.
Just add one thing does Gigabyte have any DDr3 mobo with on board graphics was thinking to get graphic card nxt month if psbl...
Old 18-06-2009, 06:15 AM   #13 (permalink)
damnbadman666
Default Re: New pc.
getting DDR3 ram with AMD proccy doesnot gives much difference
GET
Phenom 2 940 + GIGABYTE MA790GP-UD4H + 4GB Corsair XMS 800 +Palit GTX 260 sonic
Old 18-06-2009, 07:34 AM   #14 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: New pc.
@damngoodman, it's not just about difference, AMD is moving to AM3 and if one is ready to put 8k for a DDR2 board, I think it's wise to put another 1k and get AM3 board.
btw, X4 920 and 940 won't work on AM3 boards as these two are am2+ processors. YOu need to get 720 or 810 or 550 or 955 for am3 board.
Gigabyte am3 board is not available in 10k I think. one good board is MSI 790GX-G65, which is available for some 9.2k
Old 18-06-2009, 07:45 AM   #15 (permalink)
Tech addict
surinder's Avatar
Default Re: New pc.
GET
But I don't think a PC including these items along with rest of the stuff equally capable can be built under his max budget of 45K. Or has he increased his budget?
surinder is offline
Old 18-06-2009, 08:00 AM   #16 (permalink)
Default Re: New pc.
Surinder my budget has not increased for now but i have just thght if i go for a config widout a graphic card right now and get a card nxt mnth as you were saying the rates are gng to be slashed so i need to get a config widout a graphic card within 45k...so is it possible to get it within this...
Old 18-06-2009, 08:08 AM   #17 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: New pc.
X3 720: 7.5k
MSI 790GX-G65: 9.2k
Transcend 2x2GB DDR3 1333MHz: 3.6k (1.8k each)
Old 18-06-2009, 10:04 AM   #18 (permalink)
Tech addict
surinder's Avatar
Default Re: New pc.
desiibond very impressive configuration but I think he can get even AMD Phenom II X4 955 AM3 @13K just over his total budget of 45K and should not he go for GlacialPower GP-AL650AA @4.8K(due to unavailability of Antec EA 650w)just 0.6K away from VX 450w spatially when considering his upcoming graphic card.
And at next possible upgrade he must add one more module of 2GB DDR3 1333MHz to avail maximum benefits of DDR3 RAM as it works best in triple channel mode.
surinder is offline
Old 18-06-2009, 10:10 AM   #19 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: New pc.
^^ah yes. Glacialpower 650AA will be better for that price.
BTW, AMD's DDR3 memory controller is dual channel and not triple channel and hence we need not worry to have 3 mem sticks instead of two
Old 20-06-2009, 04:00 AM   #20 (permalink)
Default Re: New pc.
thnx all for your inputs specially desiibond...have finalised this config..pretty much the same that was suggested.. would be deciding on whether to get 500GB or 1Tb of HDD then and there...don't require a keyboard and mouse have it already...speakers most probably would be Creative any2.1 within 2k ie.have to get a UPS though
Processor- MD Phenom II X3 720 HDZ720WFGIBOX Black Edition Processor
MotherBoard- MSI 790GX-G65
RAM- Transcend 2x2GB DDR3 1333MHz
HDD- Barracuda 7200.12 SATA 3Gb/s 1TB Hard Drive ST31000528AS Barracuda 7200.12 SATA 3Gb/s 500GB Hard Drive ST3500418AS
Graphic card- would be getting Palit 4850 512 MB DDR5 next month...or if you can suggest any better card in the budget of 10k
Monitor- Samsung 2233SW
DVD Burner- Sony
Cabinet- CoolerMaster Elite 330 Cabinet
PSU-GlacialPower GP-AL650AA
Old 20-06-2009, 07:18 AM   #21 (permalink)
damnbadman666
Default Re: New pc.
next month 10K - u can get GTX 275 (or) HD 4890 dont worry
