hi,
I am planing to upgrade my system.
Here are the Products i finalized.
Processor : AMD Phenom 2 - 955 BE
Mobo :
Gigabyte GA-MA790XT-UD4P
Ram : 4 GB DDR 3 Transcend.
Problem is, I have a
Cooler Master Extreme Power 600w Power Supply, which has only one 4 pin cpu power connector. But the above Motherboard has 8 pin cpu power slot.
Can i use my 600w single 4 Pin CPU power connector with the Motherboard ?
Will there be any Problem?
I already have an XFX Nvidia 8800 GT OC which i will use with new config.
Does anyone know about any Molex to 4 Pin Power adapter. Will such an adapter work for my problem.
If u know about the adapter in Hyderabad please let me know.
Please help....
