Old 28-05-2009, 08:22 PM   #1 (permalink)
ajooba215's Avatar
Default NTLDR missing with no OS installed....
i know there are many threads asking for the answer of this question...but in every query made earlier by the members,they had got an OS installed... but mine is bit diff...i formated my hard drive booting from another hard drive... now i want to install the OS but i am not able to boot from cd/dvd drive .... as i start the computer... it shows `NTLDR missing` and nothing else... ... have someone got any answer fot that??
Y FOLLOW WHEN YOU CAN LEAD.....
ajooba215 is offline
Old 28-05-2009, 09:22 PM   #2 (permalink)
Default Re: NTLDR missing with no OS installed....
make sure the pc starts from cd. doesn't it ask you to press a key to start from cd? i'm not very familiar but this happens to me if i forget the xp cd inside.
xyanna is offline
Old 29-05-2009, 01:01 PM   #3 (permalink)
ajooba215's Avatar
Nope dear...thas the prob ... It ain't showing anything... It starts off with the error...
Old 29-05-2009, 01:28 PM   #4 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: NTLDR missing with no OS installed....
From which HDD r u booting now?
The one which u formatted now or the one which u used to format?
Check ur first boot device, if its set to CD/DVD rom...
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 29-05-2009, 07:17 PM   #5 (permalink)
ajooba215's Avatar
i attached it with my another hdd and formatted it and now i am trying to install the OS on the formatted hdd... and yes... i did change the first boot device to cd/dvd drive.. :-s
