Old 28-05-2009, 05:57 PM   #1 (permalink)
Project Halcyon V2.0
tkin's Avatar
Lightbulb Help In Purchasing Monitor
Need urgent help in buying monitor.
Budget=8.5k max(probably can not be stretched, parents a bit strict)
Details-
1.Need good contrast ratio (DC 10,000:1 or above) and good brightness (300CD/m2 least).
2.Need to have 5ms or less response time, I am primarily a gamer so this is important to me, I have seen what ghosting does to gaming.
3.DVI is must, HDMI is not necessary.
4.Need good viewing angle(170/160 least), needed for gaming, specially in front of friends.
5.Screen Size= At least 18.5 inch or above.
6.Resolution=1440x900 or above. HD not needed.
7.Service=Need good customer service.
8.No need for crap like speakers.
My old CRT is dying and I need to replace quickly, so help me guys.
A few selections I made, comment;
1.Samsung 2033SW
2.LG W1953T(has DC 50,000:1)
3.Dell 1909W
Feel free to suggest anything, also the points I have given are sorted according to importance, 1st point most important, 8th point is least important. Will purchase next month after xams, please share your review if you own a monitor falling in the above catagory.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline
Old 28-05-2009, 06:26 PM   #2 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default Re: Help In Purchasing Monitor
^^U've come prepared. My pick would be 2033.
Blogging at:
Technostarry
saqib_khan is offline
Old 28-05-2009, 08:37 PM   #3 (permalink)
the LG has the best image
xyanna is offline
Old 28-05-2009, 08:45 PM   #4 (permalink)
live life king like...
hot zubs's Avatar
yeah LG seems 2 b good...
Core i5 2400, Intel DH67BL-B3, 2GB Corsair DDR3, Geforce 8600GT, Seagate 1TB, LG 20x , BenQ E2220 HD, Creative M4500 , CM extreme 600W, CM 690, APC BackUPS -ES650VA
hot zubs is offline
