Old 28-05-2009, 04:56 PM   #1 (permalink)
deAdLy GamEr :P
himanshu_game's Avatar
Default URGENT!!!NEED ADVICE FOR CABINET AND CPU COOLER
my proccy q6600 temp heating a lot with temp. exceeding 77 C under average usage.
and under crysis it reaches 87-88 C .due to which my whole system temp getting higher.Around 50 C for mainboard.61 C for hdd.My current cabby is a intex cabinet which i purchased for .5k ...
NOW i need a new cabby..
PLEASE SUGGEST A GOOD CABBY ASaP...
and do i Need a CPU cooler..>
if yes suggest that also....
MY whole system is MEltING
Q6600,Abit Ip35e,4 gb ddr2 800,1 TB WD(black edition),MSI Radeon 4770,creative t6100,cm 690.
living ma dream of GAME DEVELOPMENT................
himanshu_game is offline
Old 28-05-2009, 07:24 PM   #2 (permalink)
live life king like...
hot zubs's Avatar
Default Re: URGENT!!!NEED ADVICE FOR CABINET AND CPU COOLER
CM 690 for 4200 bucks
Core i5 2400, Intel DH67BL-B3, 2GB Corsair DDR3, Geforce 8600GT, Seagate 1TB, LG 20x , BenQ E2220 HD, Creative M4500 , CM extreme 600W, CM 690, APC BackUPS -ES650VA
hot zubs is offline
Old 29-05-2009, 01:26 PM   #3 (permalink)
deAdLy GamEr :P
for 4200....
with side panel or not?
and what abt cpu cooler
Old 29-05-2009, 02:15 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Himanshu, there is one cabinet in zebronics with 220mm huge side fan. Check for this and add few more fans to this cabinet and you are good to go.
desiibond is offline
Old 29-05-2009, 02:46 PM   #5 (permalink)
deAdLy GamEr :P
which model no and for how much??
are thes zebronics cabby's r as gud as coolermaster's 690 etc ?
and wat abt build quality?
screwless design?
Now i changed d place of my cabby temp. reduced to--
CPU- 55-60 C idle
GPU--42-52 C idle
do i need a cpu cooler
my Mobo is Abit -ip35P
Old 29-05-2009, 03:05 PM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
They are decent. You can't compare it with CM 690. It costs less than 2k I think. BTW, CM 690 will become a worthy buy if you put
1 fan at top and one at the bottom and 1 one left side. Then you will find total reduction in temperatures.
Old 29-05-2009, 03:51 PM   #7 (permalink)
deAdLy GamEr :P
how much marks u will give to--
------------------------------------CM 690------- ---ZEBRONICS
1)BUILD QUALITY
2)COOLING
3)PRICE
4)DESIGN
5)CONCLUSION
and do i need a cPU cooLER?
Old 29-05-2009, 04:05 PM   #8 (permalink)
hot zubs's Avatar
Originally Posted by himanshu_game View Post
for 4200....
its without d side panel...
hot zubs is offline
Old 29-05-2009, 04:26 PM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
1)BUILD QUALITY
2)COOLING
3)PRICE
4)DESIGN
5)CONCLUSION
1)BUILD QUALITY: 8
2)COOLING: 10 (8 coolers can be installed. awesome. freaking awesome)
3)PRICE: 6
4)DESIGN: 8
5)CONCLUSION: 8
Old 29-05-2009, 04:36 PM   #10 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Thread moved to Hardware Troubleshooting.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 29-05-2009, 09:21 PM   #11 (permalink)
Crowman
Krow's Avatar
Its the Zebronics Rage. I say go for CM. If budget permits, then go for CM-690(with the transparent side panel)! Else u cn have a look @ The CM Elite 334 @ 1.8-2.2k. For the CPU cooler(if u happen to decide that u wanna buy it), u cn have a look @ the OCZ Vendetta 2 for Rs.2.5k. Another good cooler is the Arctic Freezer 7 Pro for arnd 1.6k(not sure, plz verify).
Whichever CM cabby u buy, if u install fans(80/120mm) @ the right places, the overall airflow will be excellent.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 31-05-2009, 06:50 AM   #12 (permalink)
Adhip007's Avatar
Also you can buy CPU Coolers from CM like Hyper212. Sunbeamtech's Core contact freezer 120mm.
My new Config: Phenom II X6 1100T + ASUS M5A88M + Palit GTX 260 + 4GB Ram(Corsair Vengeance) + 200 GB(Hitachi) + 500 GB(Seagate) SATA+ 1TB external(Seagate) + Corsair VX550 W Smps.
ACER TravelMate 4740
http://www.flickr.com/photos/adhip_ghosh/
Adhip007 is offline
