WinXP limited users unable to watch with Philips SAA7130 TV Tuner
My PC is using Windows XP Pro SP2. I have a newly installed Odyssey ODY 501 TV Internal tuner card with Philips SAA7130 TV Tuner chipset that uses Honestech TVR software. But I can watch the TV/run the program only with administrator a/c. If I try to run the program from limited a/cs, it will close immediately once it is opened and when I switch to the admin a/c, the program will run but not in the limited a/cs. Please help.
Re: WinXP limited users unable to watch with Philips SAA7130 TV Tuner
Oops... Didnt realize the software was no longer supported... Try "Run-It as" instead... It is also free and appears to achieve the same thing... You can get it at http://www.topshareware.com/Run-It-a...load-54790.htm
