Hi..
I am thinking to buying a gaming laptop.My budget is Rs 75,000/-.can u suggest me any notebook in similar price range and have best configuration.
Thank you....
Go for Dell. Ive used friend's dell laptops and they have a great build quality. Better than HP, Lenovo at least. I suggest u go for a lappy with an ATI GPU as there seems to be a lot of problems with the nvidia mobile GPU's!
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Change the 3GB RAM to 4GB(if u r gonna use 64bit OS) and add the sound card. Done in arnd 70k. Plus the RAM is DDR3! Dont worry abt the 3670 GFX card as 4m what ive read it appears to be better than the 4570. This config should suffice i suppose.
