Old 25-05-2009, 09:52 PM   #1 (permalink)
als2's Avatar
Unhappy Procedure For RMA seagate Harddisk
hi friends
so after 3 years of using 80 gb seagate harddisk ,it developed some bad sector and now my computer hangs ,also speed got reduced.(sometimes transfer rate is 1mbps)
so thinking of replacing as warranty is till 2011
so can anyone tell me the procedure. i am from New Delhi janak puri.
in how many days can i expect to get my drive back also will they give me 80 gb or higher gb hardisk
als2 is offline
Old 25-05-2009, 10:06 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Procedure For RMA seagate Harddisk
Not sure but when i gave my HDD, it came back in 3 days flat. Since you live in Metro it can be even lower than that.
more Info
http://www.accelfrontline.in/contact.html#delhi
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 25-05-2009, 10:32 PM   #3 (permalink)
als2's Avatar
thanks friend for reply
als2 is offline
Old 26-05-2009, 08:58 AM   #4 (permalink)
paroh's Avatar
on my side return time is between 13-15days
paroh is offline
Old 26-05-2009, 09:05 AM   #5 (permalink)
15.0 GHz
VarDOS's Avatar
yep, the service is very fast in metros. My frnd got his HDD within 5-days, but I got it in 18 days
VarDOS is offline
Old 26-05-2009, 10:03 AM   #6 (permalink)
static_x's Avatar
Even i got it in a week's time. You can go to http://myservice.accelwms.in/index.aspx and register your RMA or call at 1800 425 4535 and they will do it for you. You can check the status of your call anytime by logging on to the above site.
static_x is offline
